Question about LG LS-J0910HL Heat & Cool Mini Split Air Conditioner
LG neo plasma air conditioner does not blow cold air
  • 2,133 Answers
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Posted on Jan 04, 2011
2 Suggested Answers
  • 2006 Answers
SOURCE: hi i have a LG
It sounds like your coils are froze up or at least your thermostat says they are. If they are froze and the thermostat is functional, then your defrost heater is probably open and needs replaced.
Posted on Jul 01, 2011
INSTRUCTION OF USE OF LG NEO PLASMA AIR CONDITIONER MODEL NO S244HPND6
This is close, but I think it is Country specific, so click on top right and go to LG for your country and put in the model number ONLY. If that doesn't work, contact LG via their contact page.
Manuals & Documents - Support Search Results ' LG UK
www.lg.com > Home > Support > Support Home > Product Support
  1. Cached
Air Conditioning Systems; Residential Air Conditioners; S24AHP ... product, please refer to the Owner's Manual and other documents available for this product.
LG Support Search Results LG
Dec 13, 2016 | LG Heating & Cooling
I have a neo plasma lg 7kw will not heat LG Air conditioner
Make sure the setting on the remote is correct . Sun symbol for heating. Make sure the filters are clean. On heating, the indoor unit will 1/2 open the flap but the fan shouldn't start. The outdoor unit should start and if working properly, will be blowing cold air. The indoor unit will open the flap fully and the indoor fan will start once it gets hot then you should feel warm air. If the outdoor unit is blowing warmish air, I would say the reversing valve coil has failed or one of the indoor temp or pipe sensors are faulty. If a sensor fails, a "CH" error should appear on the display.
Mar 30, 2016 | LG Heating & Cooling
LG neo plasma error code
It means the lid is open OR it has a short circuit.
Jul 08, 2015 | LG Asmc183vm Neo Plasma Filter
I have an LG neo plasma airconditioner and suddenly it turns off after about two minutes and it comes up with a code C5. Can anyone help please
Comms Error: check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4.
Dec 31, 2014 | LG Heating & Cooling
Hi i have a LG neo plasma air conditioner does not blow hot air at all, the defrost mode light comes on and it stay on
Jul 01, 2011 | Heating & Cooling
Hi I'm trying to get the air conditioning on but I can't light is flashing on the airconditioning and 12pm is shown in remote control Could u help me to sort this matter out I have three LG neo...
We have the exact same problem with our unit. Can't find solution. Any chance you have found out the cause? We also have 3 units, in 3 different rooms. The air vent's are in our garage.
Apr 07, 2011 | LG LSC121PMA Split System Air Conditioner
I have a neo plasma LG air conditioner, i am having problems switching on to cooling, sometimes it works, other times it is just circulating the air, making the room hot, it is 4 yrs old.
Possible problem with the thermostat which might be sensing the wrong temperature and so is not switching ON the compressor. So if the AC works once it is ON then the gas and compressor seems good. So you must check the thermostat and control board. Set the AC to a lowest temp and try.
Jan 24, 2011 | LG Heating & Cooling
Need to find manual to download for LG 2.5 hp neo plasma wall mounted air conditioner
You can find it her, you just need to have the full model number, probably located in the control panel http://www.lge.com/us/support/product/support-product.jsp
Jun 11, 2009 | LG Heating & Cooling
LG LS-J0910HL Heat & Cool Mini Split Air Conditioner Logo
1,984 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
