Question about Dell U0636 Mouse
Dell mouse not responding; diagnostics results says test passed. mouse works on other PC
    Scholar:
  • 59 Answers
There is a very good chance it's one of two problems. First, while theoretically you can connect tons of USB products, sometimes USB ports can be kind of hinky... Try unplugging something else USB based and plugging in the mouse or try several different ports. Also be sure it's not plugged into a USB hub and is going directly into your computer. If this works play with the arrangement of your USB devices until you find a configuration that works, maybe you'll have to switch out a printer or external drive while using your USB mouse...
If this doesn't provide a solution the next thing to do is to uninstall the pointer device driver in device manager and allow it to re-install.
If you don't have an alternate mouse to complete the task, here is the keyboard shortcuts for Windows although depending on your version of Windows it may be slightly different.
-First hold the windows key and hit the r key (win+r)
this will bring up the run menu
-Next type mmc this will bring up a management console
-Next press the ALT key and hit the down arrow key
(this should drop down the file menu, if it doesn't please try ALT+F)
-Use the arrow key to scroll down to Add/Remove snap in and hit enter.
-Use the arrow key to scroll down to Device Manager and hit ALT+A to add the device manager to the console. Hit enter.
-Make sure local computer is selected if this menu comes up and hit enter.
-Hit enter one more time bringing you back to the console with the device manager added.
-Hit tab to get to the center console and scroll down to mouse.
(If tab isn't doing anything please hit the ALT key once.)
-Hit enter to open the tree if it isn't already
-Scroll down to mice and other pointing devices (or something along these lines) and hit the right arrow key to expand the tree again.
-Select the USB mouse with arrow keys
-Hit the alt key again then the down arrow (not together) and then the right arrow key until you get to the action menu and use the arrow key to go down to uninstall and hit enter.
-Wait a moment and then go back to the action menu (you may have to hit tab just keep trying tab and the down key (not together) until a menu opens. Go over to the action menu again and choose scan for hardware changes. The computer should recognize the mouse and now work.
I hope this helps you. Thank you.
Posted on Jan 04, 2011
My Dell XPS 400 keyboard and mouse are not working. The F and Enter keys are working. Please help
Try plugging in a different USB keyboard and see if it still does the same thing. If so try running diagnostics on yourcomputer to see if you have a hardware problem. You should have a CD that camewith the computer that has "Diagnostics and Utilities" listed undercontents. Boot form this CD and run the extended diagnostics.
If you don't have the CD you can go to www.support.dell.com and select "Drivers and Downloads". Enterthe "service tag" (serial number) of the computer. You can thendownload "Diagnostics" .
To boot from a CD disk, power on your computer and tap the key tobring you to the "One time boot menu". Insert the CD into the top CD/DVD driveand then select "Boot from CD/DVD" and hit key. Select the"Run the 32 Bit Dell Diagnostics.
If all tests pass then reload OS ( Operating Software ).
Aug 27, 2011 | Dell Computers & Internet
Hi I have a Dell inspiron and I can't get the right click button to work
In dell computers there is diagnostic... You can run the diag by pressing the FN key and turning the computer on.. It will run a small test then select custom test and choose mouse... Then you can check the working of the mouse.. If its not working there please contact dell and replace it.. If it works then reinstall the touchpad drivers from the dell website... The issue will be fixed...
Sep 02, 2010 | Dell Inspiron 1501 Notebook
I am getting memory read/write error. Try to reseat the ram.
If reseating the ram does not work, there may be an issue with the ram installed. Did you upgrade the ram yourself? You may have the wrong type of ram installed.
If you have the correct ram installed, then you should run diagnostics on the ram to be sure it is functioning correctly.
Download Dell diagnostics for your system from Dell at the following website:
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=INS_PNT_PM_1525&hidos=WLH&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
Click on the diagnostics tab and then choose "Download".
Reboot the computer and press the F12 key when the Dell screen appears. This will prompt the boot menu, use the arrow keys to select "Dell Diagnostics" and press enter. Press Tab until "Test System" is highlighted and press enter. This will run a set of diagnostics on your hardware to test all of it and determine what is functioning correctly and what is not.
If your RAM does not pass the tests, then you must replace the faulty ram. If your computer is still under warranty you should give Dell a call and have them do a service call on your computer. Telling them the results of the diagnostics test will very much speed up this process.
Best of luck!
please rate my solution
Jul 08, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron E1505 Buttons on mouse NOT RESPONDING, Left or right.
run your comp in safe mode, if still not working, run 32 bit dell diagnostic using teh drivers disc, test touchpad, if still not working replace palmrest
Feb 21, 2010 | Dell Inspiron E1505 Notebook
Dell inspirion 1000 laptop computer will not allow me to work in safe mode keeps shutting down after booting up
It seems there is a heat related issue on your laptop. I would suggest to run first the diagnostic test, to check for hardware problem.
Try removing any external devices first (Ex. USB devices) then run some diagnostic test:
1. Turn on computer
2. Tap F12 continuously on the Dell logo screen
3. Select Diagnostics
4. Follow on screen instructions
4. Wait for the test results (approximately 10-15min.)
If all test passed no problems have been found, it means there is no problem with hardware/computer. The problem is now pointing out to be software problem. Re-installing windows will fix the problem. Hope this helps
Dec 30, 2009 | Dell Inspiron 1000 Notebook
The keyboard is frozen on the dell inspiron
1. Turn on computer
If all test passed no problems have been found, it means there is no problem with hardware/computer. The problem is now pointing out to be software problem. Solution will be restoring it back to factory settings.
1. Turn on computer
2. Tap F8 continuously on the Dell logo screen
3. Select Repair computer
4. Follow instructions... then select "Dell Factory Image Restore " on the recovery options
5. Follow instructions
6. Wait for 20-25min. and computer now is back to factory settings
Hope this helps
Nov 14, 2009 | Dell Inspiron 6400 Notebook
Unexpected shutdown in dell inspiron 1545
it's not clear if the laptop shutsdown while in use or while its idle. it it shuitsdown while its idle meaning keyboard and mouse not touched for about 5 minutes this might caused by the power options from the control panel. try to turn off the power options make sure it is set to never.
if shutsdown happens while moving mouse and touching keyboard this might be cause a conflicting windows update. try to reboot computer the boot to F8 then select last known good configuration. if this fails try to run PSA test. power off the laptop then press and hold on the Fn key then press power button at the same time just one, this will run the pre-boot self assessment to check memory and hdd problems, once you see colors display press Y to continue testing, take note of any error code might display such as 0142 and 0146 this are hard drive issues and might needing to replace your hdd.
Nov 12, 2009 | Dell Inspiron 1545 Notebook
DirectSound test results: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)
Run the dell diagnostics on the sound card .
1. Restart your computer
2. tap on the f12 key slowly five times
3. select the option Boot to utility partision or diagnostics
4.select dell 32 bit diagnostics
5. Select customer test and test sound
If the test pass, try system restore , probably the problem is with the sound card drivers
if the sound test fails , shutdown the system again and remove the cmos battery and start the system without it once.Check sound again .
Thanks
proton
Apr 28, 2009 | Creative Labs SoundBlaster Audigy 2 ZS...
Graphics card failure
the error: (Under this test, results show Error code 5300: 0119, which different comments for different parameters) Msg: Detected a failure while writing and reading video memory. (e.g.) Video mode: Dh (320 x 200 16) Address A002Ch, expected to read Oh, but read 1Dh instead *
indicates the video card has failed and need to be replaced.
Apr 14, 2009 | Dell Inspiron 8500 Notebook
Dell U0636 Mouse Logo
727 people viewed this question
Alun Cox
