Question about RCA B27TF680 27 in. TV/VCR/DVD Combo
My RCA TV has a line of screen on it that plays the cable while the rest of the screen is black. The TV sometimes switches to the full screen, only for a few seconds, then becomes the small line again. HELP
  • RCA Master
  • 19,396 Answers
Hi.
If the picture is reduced to a band in the middle of the screen, then the alignment is gone. The convergence ICs must be replaced and parts in the circuit must be tested and eventually replaced.
The job cost is about $200.
Posted on Jan 04, 2011
Partial black screen on mulitple (but not all) inputs on panasonic plasma tv
Sorry but it's time to shop for another tv the cost of repairing would cost almost as much as a new unit.
Mar 18, 2014 | Computers & Internet
I WOULD LIKE TO CONNECT MY LAP TOP TO TV WHAT CABLE AND HOW WOULD YOU DO IT ?
You will need
  • a PC or Mac laptop computer
  • a digital TV
  • a VGA 15-pin connector cable; or an S-Video cable and mini to RCA audio cable;
  • or a wireless converter
More information you can visit:http://www.videojug.com/film/how-to-connect-your-laptop-to-your-television.
If you need laptop accessories, such as Dell Latitude D620 Keyboard, toshiba a45 keyboard, gateway 450rog keyboard etc, you can visit www.udtek.com.
Apr 12, 2010 | Acer Aspire One AOA110-1588 Notebook
Black vertical lines on flat screen
All plasma an lcd tvs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They can sometimes be fixed, but it is a pain. An yes I have done it, and the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. Good luck.
Jul 12, 2008 | RCA L26WD26D 26 in. LCD TV
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
Black vertical line on p42w34p plasma
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Dec 31, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Cannot get picture/menu on screen!
The Sony recorder is connected to the TV via the RCA cables (for both audio and video)? How many inputs does your TV have? One cable input and one RCA line in (making a total of two? Did you eliminate the possibility that the recorder might be defective by trying it on another TV?
Dec 25, 2007 | Sony RDR-VX555
Sometimes no picture on RCA tv
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Oct 28, 2007 | Quasar SP-3233 TV
Line down center of screen rest of screen black
no not fatal, but sick. this problem you are having sounds like you have a vertical sweep problem.. It could be the vertical output IC, the sweep power supply or a capacitor or two is bad. If you have printed circuit board soldering experience, you can try and fix this yourself, but if you do not, play it safe and call in a pro to assist you in this repair as it should not cost more then 100 bucks to repair. Good Luck
Apr 29, 2007 | Thomson 24WK25U 24" TV
Black Box
i had the same problem with my rca truflat.. i read from a posting of a similar problem with a different tv brand to switch your closed caption options 'off' or set it to a 'cc' option instead of the 't' options.. (this was done through the on-screen menu..) i gave it a try and it worked for my tv.. hope it works for you..
Aug 16, 2006 | RCA 20F610TD TruFlat TV/DVD
Playing back widescreen problem
The TV itself uses the CTC203 chassis and is not capable of switching between normal and widescreen. This is an issue with your DVD player and not a problem with the TV.
Jul 16, 2006 | RCA F27442 27" TV
RCA B27TF680 27 in. TV/VCR/DVD Combo Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
