Question about Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312
My freezer is too cold - things are rock solid
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Jan 04, 2011
  • Lawrence Oravetz Mar 10, 2014
    Temperature is controlled by the thermostat. If it won't adjust to your likeing then a replacement may be necessary.
Why is it taking newly placed things days to freeze in my upright freezer? Already frozen things are still rock-hard.
Confirm freezer temperature to be about 0 F or coolder. Suggest if frost free near the air flow if not frost free on lower shelf with cooling coils.
Jun 29, 2017 | Freezers
GE GSS22JFMCWW
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
these are the usual suspects.
heater in the back wall of the freezer:
thermal switch also in the back wall of the freezer
Aug 11, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
I have a Kelvinator upright freezer model k330uf the bottom section does not work
Sounds like its got blockage.
There is a channel that allows cold air to "fall" into the bottom chamber. There is also a return. Typically the "fall" chamber is choked with either something that fell in and was trapped, frozen solid with ice or algie has grown and closed the hole.
The best thing to do is empty it completely and inspect the drop channel.
Put all your frozen goods in ice chests to keep them from thawing out.
Good Luck.
Jan 08, 2015 | Kelvinator Freezers
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Jan 08, 2011 | GE Freezers
Just open the chest freezer and the meat is defrosting still plug up the light is still on, do not here a sound
Go buy some charcoal and call some friends.... Sorry. Transfer as much as possible to neighbors freezers. If that's not possible keep the freezer as full as possible. Solids hold their cold much better than air.
Could be many things. Remove the thermostat control and cross the wires. did it go on? Replace the thermostat.
Take a multi-testor and check for power at the motor/ compressor. If yes- the compressor motor is bad. Probably fatal for the unit. If not- why is there no power? Follow the supply wires back up line until you find power. replace the part that has failed.
Good luck
Spencer
Oct 07, 2010 | Whirlpool Freezers
Philco Freezer - replace/repair seal & plastic around top
Good day,
Unlikely you would be able to repair if the inner liner is coming apart.
A local appliance parts house may be able to supply universal gasket to fit to the machine but again, if the inner liner is bad it could prove to be fruitless.
Oddly enough, if you visit supermarkets you will see chest type freezers with no top at all.
Seems like a terrible loss, but it's not.
Cold air falls, hot air rises. When the freezer generates cold air it doesn't spill out the top. It settles into the bottom of the freezer, and stays there. Likewise, warm air rises and has no interest in going into the freezer cavity.
Bottom line. Very little loss.
If appearance doesn't matter, and you can get it close, you should be able to continue to use it.
Your choice, but I thought you would like to know the physics involved here and how it does or doesn't affect you.
Mar 28, 2010 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Not cold enough
Check the temperature setting to ensure at least the one-half way mark. If o.k., then you could have a refrigerant or compressor-related problem. Contact an appliance service company.
Feb 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Fridge working fine but freezer keeps freezing rock solid in a matter of weeks
check door seal fit tightly.if its frost free make sure drain is clear at the bottom of evaporater if all ok check defrost heater and sensors..
Sep 28, 2009 | Freezers
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312 Logo
191 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
