Question about Kenmore 67632 Electric Dryer
The dryer isnt putting out any heat but is running any suggestions?
  • 264 Answers
Yep, your heating element broke. If you open up the back of the dryer you will see what look like springs surrounding the drum. Follow the springs until you find the break. Replace the element. Hope this Helps.
Posted on Jan 04, 2011
Testimonial: "thank you very much. very helpful"
What can i check to see why my maytag bravos dryer isnt drying?
[Always disconnect the dryer from any power source before checking.] Dryer heating circuits have several parts in the series circuit that must all work (kind of like a string of Christmas tree lights) so you'll want to check each one in that series. These likely include the motor switch, timer switch, temperature selector switch, temperature controls/thermostats (usually three of these) and all connecting wiring plus the heating element. Of course, one should always make certain the dryer is receiving 220 volts power supply from the wall outlet before starting to troubleshoot the dryer. Most dryers operate with 110 volts, only using the 220 volts for the heater circuit. A dryer getting only 110 volts could run, but not heat. This doesn't happen often, but is always worth checking.
Aug 20, 2014 | Maytag Dryers
The unit is running but is not drying the clothes.
notreading in your question that the dryer isnt heating i will assume it is heating yet not dryer the clothes and have ya check for a blocked and or chrushed vent
Jul 02, 2011 | Whirlpool LER5636P Electric Dryer
Dryer will not fire. Fuse is good and door swithch seems to be good. When you push the button in to turn on nothing happens. Dryer is just over a year old. Any suggestions.
then it must be either in the switch or the motor has burned out is the heating coil heating though the barrel isnt turning ??
Feb 15, 2011 | Estate EED4400WQ Dryer
The dryer isnt heating what is wrong
rw
wer
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 24, 2010 | Maytag MDE2600 Electric Dryer
The everything in the dryer is running fine but the heat isnt working
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 14, 2010 | General Electric DBSR463EGWW Dryer
Dryer isnt heating and the heating element is ok what else could it be?
some dryers have a back up system, that will not let the coils heat up if there is no out put of air, such as at the end of your dryer hose, I would check and make sure your filter and your hose are not clogged, if you take the top off and you see the coils turn red thats because there is air flow, if you put the top back on and no heat from the coils it is a good bet you have a plugged exhaust.
Jun 11, 2010 | Dryers
LER8620PWO dryer isnt heating any suggestions
If you have a gas dryer then check out this tip...
If you have an electric dryer then check out the tips at the bottom of this tip...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Heatman101
Mar 21, 2010 | Whirlpool Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
KitchenAid elec. dryer not heating
check and make sure your breaker isnt part way flipped .... dryer will run on 110v but wont heat unless it gets 220v ,,,, break may look to be on but not ,,, turn off breaker, wait 30 sec and flip back on hard / larryyb
Dec 05, 2008 | Dryers
Dryer problem
heating element or limit switch is out both are inexpensive to replace
Aug 20, 2008 | Estate EED4300SQ Dryer
Kenmore 67632 Electric Dryer Logo
136 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
