Question about Brother MFC-8460N All-In-One Printer
Brother 8460 paper tray error and terrible clicking noise.
checkitright
  • 1362 Answers
SOURCE: Brother MFC 8460 N, all
Make sure the stopper in the paper tray is snug against the paper. sounds like the paper is not properly in place and the tires are making the noise.
Could be it's trying to lift the tray and it can't, determine why; something stuck, out of place,
Posted on Jul 21, 2008
d2704
  • 101 Answers
SOURCE: Clicking noise on power on and every print
This can be all that is pleased , main reason there is defect of lubrificant there where this it is necessary, recommend you to apply to nearest service.
Posted on Mar 07, 2009
SOURCE: brother hl 4040cn will not load paper from tray
Remove main tray. Check adjustable paper back stop. If the backstop is set so that the paper sit too tightly in the tray....it will prevent the spring loaded front portion of the tray to lift up allow paper to contact the pickup roller. The clicking sound you hear is the paper lift mechanism trying to push up the paper. Arrange both backstop and sidestops to allow some movement of paper in tray.
Posted on Apr 15, 2009
SOURCE: Brother HL-5250dnt - Clicking Noise and not picking up paper
You may have to use a true Brother toner cartridge as I have the same problem with me MFC 8500. If I use a compatible cartridge it clicks and if I use a geniune Brothr cartridge it does. Brother direct brought this to my attention.
Posted on May 30, 2009
SOURCE: My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Posted on Mar 11, 2010
Mfc-8460
Whats the problem? Lots of printer trays are like that. The printer, when powered on, will lift that. Look on the side of the tray there is a mechanism that makes contact with a gear inside the printer.
May 02, 2013 | Office Equipment & Supplies
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
Clicking noise with MFC-8640D another case
Usually it's because the paper is too tight in the feed tray. The paper length tab on the end away from the feed roller is too tight. If you cant rotate the gear on the paper tray and lift the paper, it's too tight for the machine to lift.
Aug 12, 2009 | Brother MFC-8460N All-In-One Printer
Paper curls on 8460 Brother
The following is Brother's take on your problem. All of their solutions have some merit but the one I'm leaning toward is overstuffing of the paper tray. It's common in most offices (and homes for that matter) to have a tendency to stuff the paper tray when it runs out.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000000618&Sympt=The+faxes+I+receive%2c+copies+I+make%2c+and%2for+documents+I+print+from+my++computer+have+a+curl+or+wave+to+them+when+they+feed+out+of+the+Brother++machine.+What+can+I+do%3f+(paper+curl)&Model=270&ProductGroup=5&Keyword=paper%20curls&ProductID=MFC8460N
Apr 23, 2009 | Office Equipment & Supplies
Brother hl 4040cn will not load paper from tray loud clicking noise coming from paper tray on dislplay it says no paper
Apr 13, 2009 | Brother HL4040CN Laser Printer
Mar 05, 2009 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460
Hi
There must still be a piece of paper in the machine check the fuser section at the rear of the machine maybe be piece there or check at the paper cassette area remove cassette and check that the paper hasn't got jammed as it feeds through.
Thanks
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460 N, all in one copier. Loud clicking noise (from tray area) when trying to make a copy, it will not do a copy now, says to load paper - tray has fresh, higher quality paper in it. Is this...
Jul 21, 2008 | Brother Office Equipment & Supplies
Brother MFC-8460N All-In-One Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
