Question about Toshiba Satellite A135-S2276 Notebook
My laptop will power on and the first screen will appear that says Toshiba. The next screen is just blank though with ( _ ) blinking on and off and it will not boot up any further
25-charater product key
Posted on Jan 04, 2011
Hi, I have Toshiba Satellite A305 S6905 model.
It is more on a hardware issue. The battery needs to be drained. Once on, let the battery drain and re charge it for 4 hours.
Oct 29, 2013 | Toshiba Satellite A135-S2386 Notebook
My toshiba l355d black screen all fans and lights are working
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 03, 2012 | Toshiba Satellite L355D-S7901 Series...
Whenever I try to start my Toshiba Satellite Laptop the Toshiba logo comes on but then the screen goes blank and all there is is a blinking underscore in the upper corner of the screen; I already set
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Jul 15, 2012 | Toshiba Satellite Computers & Internet
Toshiba a135 laptop screen goes blank during battery use. Only way to recover is to put the laptop to sleep blinking orange and then restart. This action keeps the screen on. Could this be a bios problem?...
It's probably not a BIOS problem.
You should go to Control Panel --> Hardware and Sound --> Power Options --> Change plan settings --> change advanced plan settings.
Try configuring the setting for "Plugged in" and "On Battery" to be the same. That way your laptop won't go through wierd configurations when you unplug.
Try cleaning your computer with compressed air too.
May 10, 2010 | Toshiba Satellite A135-S2276 Notebook
Monitor
there are internal wires that need to be serviced by a licensed technician .....
Jul 13, 2008 | Toshiba Satellite A215-S7462 Laptop
Black screen
just clean your ram and resit it.
If the problem not solved then you are having display adapter problem and you have to send the laptop for repair
Apr 05, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
