Question about Intermatic Timer PF1202T Multi Circuit Freeze Protection Controls for Pool
I need only the thermostat part of unit pf1202t. Please advise plus price.
1) Smarthome sells for $80
Double check model numbers
http://www.smarthome.com/42699/Intermatic-PF1103M-120-240V-Freeze-Protection-Control-Timer-Mechanism/p.aspx
2) Google search for: Intermatic freeze protection thermostat
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Posted on Jan 04, 2011
Fridge S/N is MFQ702718 12 y.o. req's a serv call + new thermostat (min). Should I pay for service call & repair or replace fridge now during the January sales?
the price of a service call plus labor time plus parts will probably be half the price of a new unit
If the problem is compressor then that will be almost the price of a new unit
I would suggest that you consider the new unit plus an extended warranty
Jan 22, 2016 | Fisher and Paykel Refrigerators
Need ordering information for a replacement battery for your E-500 Battery info I have is Model PS-BLM1 Li-ion barrety pac BLM!. Please advise, price, availibility, and price plus how to order...
Olympus no longer lists the BLM1 battery, but they do have the newer BLM5 battery for the E-500. The BLM5 requires a different charger, however. Full information (including price and ordering) is available on their web site at
http://www.olympusamerica.com/cpg_section/cpg_support_accessories.asp?id=1192&ct=2
Jun 02, 2011 | Olympus EVOLT E-500 Digital Camera
Pump continues to run constantly after freeze protection was engaged. The temperature is now over 70 degrees F but the pump will not turn off unless you flip the override switch on the outside of the...
The freeze protection thermostat has gone bad.
To confirm this, disconnect wiring from freeze control.
Freeze control can be purchased separately.
Search: Intermatic Freeze Protector
For example, Smarthome:
http://www.smarthome.com/42697/Intermatic-PF1102M-240V-Freeze-Protection-Control-Timer-Mechanism/p.aspx
I am familiar with wiring for Intermatic pool controls.
If you have problem, add a comment with exact model number or photo of product.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Also if you re-post question another question at Fixya with exact model number, I will probably see it.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call
Feb 21, 2011 | Intermatic PF1202T - Pool-Spa Freeze...
The freeze protection just quit qorking when it dropped to freezing i turned the dial to 45 and it still will not come on has been working non stop for about 4 days. i am in the dfw area
You can replaced the freeze control without buying entire timer:
Google: "Intermatic thermostat freeze control" to see cross selection of choices.
For example Smarthome sells PF1103 for $80: works for 120 or 240
To prevent freezing right now, the pump should run full time, so pull trippers off the timer dial, and mover override lever to ON position. This will keep the pump running.
When the temperature rises, put trippers back on dial, and then order new part.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 06, 2011 | Intermatic Timer PF1202T Multi Circuit...
My PF1202T was running non-stop, as if it were in freeze protection mode even when it was 50 degrees. I took cover off and checked connections on relay and thermostat. Everything felt fine, put back...
I'd be inclined to say the thermostat is the culpret. You can test the thermostat and the relay with one test. First, turn the power to the timer OFF, of course. Then disconnect the two wires that connect to the thermostat and temporarily wire nut them together. Turn the power back ON, (you should hear the relay kick in) and carefully untwist the wirenut to break the circuit. If the pumps turn OFF you know the thermostat is bad. If the pumps stay ON, the contacts on the relay are sticking closed, causing the pumps to always be ON.
To be safer, you can turn the circuit OFF first, make sure no thermostat wires (that you previously disconnected) are touching anything and turn the circuit back ON. The pumps should stay OFF. If they come ON, the contacts on the relay are sticking closed.
Alternatively you can temporarily wire a single pole switch in place of the thermostat.
Since the timer on the left (filter pump) feeds the load side of the relay, which in turn feeds the second timer, it's also possible that the contacts on the timer on the left are sticking closed.
Remember that the only thing that controls the relay is the thermostat.
Jan 20, 2011 | Intermatic Timer PF1202T Multi Circuit...
How do I wire a Honeywell room thermostat T6360B1028?
The red goes to R or rc and the blue would go to C or common sometimes its BK on the thermostat and the yellow would go to Y.
Jan 22, 2010 | Honeywell Programmable Thermostat Heater
Need to purchase charger - G4m20211-2347-E-16.
the price is $22 as a standard level 4 original batteries but beware of duplicates
Aug 06, 2009 | Electric Bicycle Motor, Bike,electric...
Mal functioning thermostat on duo therm model 620215
Ok;
Upgrade kit Part# 3307713.010
Price is 274.75 Plus shipping
Can be purchased from any Dometic dealer or I have an ad on this site. Coach Tech RV
Thanks for using Fixya
Jerry
Mar 29, 2009 | Dometic Rooftop RV Air Conditioner
Scalding hot water
If your water is too hot, then either the water tank thermostat or the wiring to the indoor unit is defective. When the water reaches the set temperature, then the tank thermostat contacts should open up and shut off the combustion unit. If the combustion unit does not shut off, then check all wiring and relays. A manual is located at http://www.scribd.com/doc/29550374/Amana-HTM-Plus-Manual
Dec 03, 2008 | Water Heaters
Intermatic Timer PF1202T Multi Circuit Freeze Protection Controls for Pool Logo
113 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
