Question about Riso RZ220 Duplicator
Risograph GR3770 - cannot pul out the drum, Error code T14. How can I pull it out :)? thanks
  • 55 Answers
This solution is ONLY for pulling out the drum.
Open front door. If you look at the metal housing below the drum you will see a plate mounteg with two screws. Get it off and you will see a small lever. Turn it right to loosen the drum. Be extremely careful when pulling out the drum. If the drum is not in zero-position it might be a bit difficult (e.g. have a look at the master clamp). Please note that it may be difficult to insert the drum again.
Posted on Apr 27, 2011
Pulled drum out and now it's stuck outside the machine Risograph CR1630/1610
Hello
It seems as if the machine was not in the home position when the drum was pulled out.
The pressure roller is in the up position stopping the drum from entering.
To reset the pressure roller, you will have to remove the back cover, behind the power supply you will see a arm with a heavy spring on it. pull the arm up until it clips into the solenoid.
Once the preasure roller is back down look into the machine, there is a gear with 2 holes in it.
The hole on the left must be in line with the hole in the frame, the hole on the right on the gear must not line up to any holes but show to the exit side on the machine.
I hope this helps you
Regards
Apr 27, 2011 | Riso Office Equipment & Supplies
Call service engineer code T14 just come up on my Riso GR3770 I am fairly conversant with my machine but I have not seen this before - can you help?
Try to hold both and press the M/L P/L button then turn on, u r entering the test mode of the mcahines,, then press 97 and start button.
Jul 13, 2010 | Riso RZ390 Duplicator
Anybody know if Risograph GR hd black ink is ok for use in Riso FR machines?
Short answer is no. RISO GR HD ink is only compatible with a GR3770, a 600 dpi machine.
Mar 05, 2010 | Eagle Signal Br1 30min Reset Timer
Riso gr 3770 error T14
how can i solve the Error T14 for Riso Gr 3770
Thanks
May 12, 2009 | Riso RZ220 Duplicator
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
Riso gr 3750 error T14
Means a clamp error. Inspect the clamp on the drum to make sure it moves smoothly and that that clamping mechanism in the back of the machine works as well.
Apr 06, 2009 | Canon PC-140 Black and White Copier
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
Error Code
From memory (haven't looked at one for about 7 years) the T1 fault was when the latch hadn't disengaged.
Back panel off, towards the middle at the bottom there is a small solenoid with a kindof latch/hook. It will be engaged onto a small lever.
IF it is the same fault as above, it's really easy to sort, by pushing it off with a screwdriver, as a lever.
The way to tell is if the roller under the drum is still engaged. If so, you won't be able to pull out the drum.
Let me know if it helps, or if you want another suggestion.
Feb 14, 2008 | Riso RZ220 Duplicator
520 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
