Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
How do you disassemble the Badger5 1/2 horsepower sink erator.model #5-81
The badger has two parts:
1) The sink strainer basket that attaches to sink with three screws visible from below.
2) The disposal which connects to sink basket with connector ring.
There is a rubber washer between disposal and sink basket
how do you disassemble the Badger5 1/2 horsepower - geno_3245_218.jpg
If you drop disposal loose from the sink, you can get spoons and other stuff out.
The disposal itself does not come apart for repairs.
I wrote tips for replacing disposal, which include information you might be able to use:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, and push in reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, use new washer.
Attachment ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, taphow do you disassemble the Badger5 1/2 horsepower - geno_3245_219.jpgom nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal.
Posted on Jan 04, 2011
  • Anonymous Mar 12, 2011
    If answer is not satisfactory, then add a comment with your solution that worked, so others can be advised correctly.
Leak from area where cord comes out of the in sink erator
Not good seal could be bad are you sure it is not leaking from the top and running down the side.Fill sink all the way then pull plug get a flashlight and examine well.
Apr 17, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My badger 5 plus in sink erator is not working
Here is a tip the I wrote that may help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammedheatman101
Sep 04, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My waste disposal unit wont turn on
Theres a reset button on the side of the thing.  Also check the breaker box to see if the switch got flipped.
Nov 19, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
I get a buttery flavor from the hot water
This is the first I have ever heard of that I would contact In Sink Erator with your model and serial numbers they have excellent customer service the number is on the sticker on the unit
Nov 04, 2009 | Buck In Sink Erator H770-SS H770-SS...
Disposal blades sounds like metal to metal
Does it stop turning, then shut off? Another words, seizing the engine? Do you have to jar it free before hitting the reset? If so, there is something stuck in there, if not, sounds like it might be time for a new one. Very simple installation...same housing, so you wont have to change the strainer.
If switch operated, make sure the switch is "OFF" and disassemble wiring.
Loosen nut on the drain arm and raise.
simply spin the housing part (new one with come with pictures/direction).
Really is an easy fix and can get a disposal for fairly cheap money (anywhere from $60ish to $hundreds). Depending on usage, a 1/3 horsepower will probably do the trick. !/2 is your best bang for the buck though. Good luck and dont hire a plumber for over $100 when you can do it yourself in 30 minutes.
Aug 28, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
In sink erator( 5 horsepower) doesnot function
On the bottom of the disposal is a place for an allen wrench. Take and turn the unit with the allen wrench to break it loose. It sounds as if has something sticking the blades.
Jun 03, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
How do I change the rubber baffle that prevents
You need to remove it from under the sink and insert a new. Then reinstall. Not a real hard job if you are handy.
Kurt
Mar 17, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
2,609 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
