Question about Dell E176FPC Monitor
My monitor works one minute and won't tun on the next time. If I unplug it for extended periods of time, it works. What is going on?
  • 11,361 Answers
It may have dying power supply due to bad caps, that will be the first place to look.
There are more than one version:
http://www.lcdrepair.us/Invpowersupply.html
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Replacement board: http://www.lcdrepair.us
Posted on Jan 04, 2011
Will i need to get a power board or logic board to get my lg plasma tv working again?
You have some bad caps/resistors in there. They are about the only thing that can change value as you use the set and then revert to original condition. Transistors and diodes either work or do not work.
Best bet is to research carefully the symptoms on google and find out via a consensus of blogs what board is likely to be responsible for the anomaly. Look there and if necessary swap it out with known good board.
Sep 01, 2015 | LG Televison & Video
Monitor Turns Off , I have to unplug for a couple of minutes and then it turns back on.
You don't have your setting changed for the monitor to shut down after a period of time?
Jun 09, 2010 | Dell IN1910N 19" Monitor
No power It will not turn on and have checked outlet seems like it is either getting no power or the power cord does not work
We had this same syndrome, and found out that in order to reset the Wii, leave it unplugged for about 20 minutes. Our model seems to be unresponsive if we leave it plugged in for an extended period without any use. Now we just leave it unplugged all the time, and plug it in when we want to use it. It works fine everytime now, and remembers all its previous settings.
Hope this helps.
Feb 17, 2010 | Nintendo Wii Console
2003 ford ranger extended cab 4 door the door
you have a door switch going bad. next time the lights dont go out unplug them one by one until the lights go out this is the one that is bad
Dec 30, 2009 | Ford Ranger Cars & Trucks
Defrost cycles needlessly for extended time period
Without knowing what the problem was with the old board, you're not going to be able to figure much out, I don't think.
Did you check that temperature sensor I mentioned? You will have to pull the top off to get access to it. Normally found connected to one of the tubes for the coil, silver in color, with 2 wires connected to it, near the bottom of the base of the unit.
Dec 13, 2009 | Heating & Cooling
Syncmaster 181T periodically shuts down
monitor ACER 17" S/N #ETL460C148710572-B4045 just off for minutes at a time. Please solve this.
Nov 12, 2009 | Samsung SyncMaster 181 T 18.1" LCD Monitor
After extended period of no use, screen stays blank when woke
It is leaning towards your screen is going out and needs replaced.
May 11, 2017 | Samsung SyncMaster 931BF LCD Monitor
Green line vertical on screen keeps appearing
in the monitor menu button you will be having a option called "degauss" give that when it appears ...
if you still persist the same problem then there may be some problem in the CRT tube ....
just take your monitor to the technician ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
Aug 12, 2008 | Samsung SyncMaster 240 T 24.1" Flat Panel...
CM2015 15" LCD Monitor
Sometimes over long periods of tiem these buttons on the LCD monitor become lodged and they begin to stick. From frequent use the board that controls these small charges that allow the board on the mother board to know what button is pushed shortout or go bad, the pads beneath them go bad as well. You may want to purchase a new monitor! I repair these all of the time, sometime you just have to say goodbye! Sorry!
Nov 26, 2007 | Balance CM2015 15" LCD Monitor
Dell E176FPC Monitor Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
