Question about Belkin Tunebase Direct Whandsfree F8Z442
I have a belkin F8Z442 with my iphone4, and there is plenty of electric interference in the speakers.
Belkin 30e puts out only .38mbps
Check ALL cables, reseat, replace. Contact your ISP for good signal, have a ISP tech analize the signal. If it's a Wireless connection many things will cause a weak signal, interference, distance, firmware update needed, outside interference, bad connections, the device is bad itself. Is the Belkin Secured? Change Channels, update firmware, reset the device. Try here for Belkin Support and User Manual: http://www.belkin.com/support/dl/P74559-B_F5D7230-4v7_man.pdf AND here: http://www.belkin.com/us/support-article?rnId=3588
Apr 19, 2013 | Belkin Computers & Internet
Laptop speakers picking up interference?
The speaker may not be making proper electrical connection to the motherboard.
Reseat the speaker connection to the motherboard.
Jun 04, 2012 | Dell Latitude E6510 Notebook
N600 Belkin Dual Band N+ Router Range Problems
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default. Change to anotherchannel.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedropouts and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
May 30, 2012 | Belkin N1 Vision Wireless Router
Wireless router routinely drops connection with Macintosh?
1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
Mar 06, 2012 | Belkin PLAy N600 DUAL BAND N ROUTER
F64230-4 v3 reduced connectifity
Feb 25, 2012 | Belkin (F6D42304) Wireless Router
I can't connect my iphone4
iPhones only support 2.4Ghz (Wireless G not n)
Feb 01, 2012 | Belkin F5D7234-4 Router
I have an ongoing buzzing/interference sound with these speakers - THey are new - I bought them because I thought it was the old speakers that I had which cauused the problem, but it persisted with these...
Sounds like electrical interference. If you can, try moving the speaker wires. They are like antennas. They might help to find the offending device. Otherwise try moving electrical devices away from the speakers and wire. Do it one device at a time so you will know which one is causing the problem.
Sep 21, 2010 | Logitech X-530 Computer Speakers
Wireless keeps going on and off
There are several things causing you to lose connection, these range from weal signal strength, interference from other wireless devices, electrical interference etc. please click on this link for possible solutions and follow my instructions :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Jan 28, 2010 | Belkin (F5D7230-4) Router (587009)
Router loses connection to Internet
Note : The steps below are applicable only for Belkin routers.
  1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  2. You will get a login page. Leave the password blank. Click Submit .
  3. On the left side of the page, click Channel and SSID below Wireless .
  4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
  5. Click Logout in the top right hand corner.
Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
CauseYou are not able to connect wirelessly mainly due to environmental interference. When the wireless channel is set to auto, the router will cycle to though channels when it detects significant interference. When the router changes channel the wireless connection will reset itself and disconnect all wireless clients connected to the router. SummaryWireless signals are prone to interference from cordless phones and electrical appliances (e.g., vacuum cleaners, microwave ovens). This is the reason wireless connections can drop. This article explains how to overcome frequent wireless disconnections by changing the channel number (frequency) on the Belkin router.
Nov 08, 2007 | Belkin (F5D7231-4) Wireless Router
Belkin Tunebase Direct Whandsfree F8Z442 Logo
54 people viewed this question
Top Belkin Audio Players & Recorders Experts
woodzowl307
Renee Knafel-Bullock
Are you a Belkin Audio Player and Recorder Expert? Answer questions, earn points and help others
