The on off , heat swith is broke where can i get parts
  • 472 Answers
If you had the model or manufacture i may be able to help you out a little more...the best advice i can give is type in your model number to unit on a search engine on the web but also type parts replacement behind it... hopefully you can find a few parts distrubitors out there to help you out...
good luck
Posted on Jan 04, 2011
Ddr94a techwood
This receiver has 100 watts per channel. If b side speakers aren't working you may have them hooked up wrong. Try connecting the B speakers to A terminals to make sure speakers are functioning. Please see the user manual below for wiring diagrams.
http://weltonusamanuals.s3.amazonaws.com/omddr94.pdf
Mar 30, 2014 | Audio Players & Recorders
I have an 2001 grand prix there was an atempted theft saw the ignition key swith turn tab popted off . vehicle startes for three seconds an shuts off .
When the thief broke away the switch, he most likely broke the part that reads the code from the key. The fact that the car starts for 3 seconds and then stalls is a tell tale sign that the antitheft has failed. The injectors actually turn off because its not reading that code properly. You have 2 options. Replace the ignition with an original OEM ignition and the have the dealer reprogram it to accept the key signal. Or bypass the antitheft entirely. I'd suggest the bypass just due to the cost of dealer fees and OEM parts. But its all up to you. PS. You can install the bypass yourself and drive it that day. Here is a link explaining the system and gives you some options for DO IT YOURSELF fixes.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 06, 2011 | 1997 Pontiac Grand Am
The on off switch broke off.
***Disclaimer***
If you are under the age of 18 please get a parent or an adult to supervise please. This repair calls for a Hot Soldering Iron and or another hot heat source to melt plastic. You can be injured and nobody wants that.
If it broke on the copter itself you may be able to remove the switch and replace and resolder. If it happened on the remote open the remote and remember to keep track of how many screws and whee they came fromonce you have the top cover off get a small screw and heat it while holding it with a pair of plyers or hemostats, not red ht but hot enough to melt into whatever remaining plastic is left of the original switch. If NO plastic is left then you have to eaiher replace the switch itself, requireing you to find an available swith and resoildering it onto the board. Good Luck!
Dec 28, 2010 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Oven does heat up and spark ignitors do not work
you either have a bad spark module or the swithes are bad.if you remove the knobs off the four valve stems and remove the panel you'll see the spark switches,they come all together on a harness and connect to each valve,most likely this is the problem,part number 74007095 and it's around 25 dollars nad the spark module part number is 8215557 and it's around 30 dollars
Dec 03, 2010 | Magic Chef CGR3742 Gas Kitchen Range
How difficult is it to replace the connections to the heater hoses? They broke off trying to disconnect the hoses from the firewall.
Do you mean the pipes that come through the fire wall broke off? Those are part of the heating core. You must replace the heating core.
Jun 30, 2010 | 1997 Cadillac DeVille
I have a 21 year old john deere 175 hydro lawn tractor with a 38 inch deck and it needs a new motor and a new swith to engage the lawn mower deck how much is it worth with those being broke ?
Trans 150$.Mower deck 50$.Hood 50$.Fender deck and seat 75$.Front axle and spindles 75$.Electric clutch 40$.This is what you can expect to get if you part it out or you can trade it in for 250$ on a new Deere.
Mar 21, 2010 | Peg Perego John Deere Turf Tractor
Sterling model TF-45, thermostat calls for heat, gas valve opens up, thermocupler starts pilot, unit fires up only to shut down within 30 seconds or so... I had replaced the high limit a while back,...
Sounds like you broke the hot surface ignitor ?? he was on about the flame sensor a rod .so replace what you broke and clean the flame sensor ,also check the pressure switch.
May 08, 2017 | Sterling Heating & Cooling
1985 chev S-10 4x4 6 cylinder pickup having starting problems
Check your electonic ignition swith under dash that the ignition acuator rod connects to about $8 part at parts store
Aug 12, 2008 | 1985 Chevrolet Chevy
Heating & Cooling Logo
11 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
