Question about Intuit QuickBooks Pro 2007 Full Version (299116)
I cannot save a backup copy of my quickbooks 2007 it verifys the data and then says the back up was unable to save
Rknrobbyy,
Try this: with the QB file open go to FILE..... UTILITIES....VERIFY DATA (this will go thru a process to identify if there is a problem) If there is a problem QB will let you know then the next step would be to rebuild data.
IF this does not work there are a few other things you can do. You can call me @ 612 718-3023 and I can walk you thru the process. ThanksTammie Nasseff CPA
Posted on Jan 05, 2011
I am getting error codes 6129,0 and 6073, 816 on my quickbooks 2008. What can I do to open the company?
This error can occur when:
  • Data is converted or restored over a network.
  • Several computers are acting as host for the QuickBooks data file.
  • QuickBooks is unable to communicate with the server.
  • There is data damage in your company file.
If the error occurred when you were restoring a company file from a backup or updating a company file to a newer version of QuickBooks over a network:
  1. Copy the backup file (.qbb file extension) or the company file you want to update (.qbw file extension) to a local hard drive.
  2. Restore the backup or update the company file.
  3. Copy the restored or updated company file back to its original location.
If the error occurred when you were trying to open and use a company file:
  1. Update QuickBooks to the most current release on all computers that open the company file.
  2. Close QuickBooks on all the computers with access to this company file.
  3. On the computer you select to host the company file, switch to single-user mode, and then back to multi-user mode:
    1. Open QuickBooks and open the company file.
    2. Choose File > Switch to Single-user Mode.
    3. Choose File > Utilities > Stop Hosting Multi-User Access.
    4. Choose File > Switch to Multi-user Mode.
    5. Choose File > Close Company to close the company file.
  4. On all other computers that will use the company file, stop hosting multi-user access :
    1. Press and hold Ctrl while you open the QuickBooks program and continue pressing Ctrl until QuickBooks opens completely. This opens QuickBooks without opening a company file.
    2. Choose File > Utilities >Stop Hosting Multi-User Access. If that option doesn't appear, the computer is not hosting and no further action is necessary.
    3. Repeat steps 4.a and 4.b for each computer other than the host computer.
  5. Configure the QuickBooks server for multi-user access:
    1. Click the Windows Start button and choose All Programs > QuickBooks > QuickBooks Database Server Manager.
    2. Click the Scan Folders tab.
    3. Click the Add Folder button, select the folder that contains your QuickBooks company file, and click OK. Repeat this step if necessary to add additional company file folders.
    4. Click the Scan button to begin scanning. After the scan is finished, the company files in the scanned folders are configured for multi-user access.
  6. Open the company file in QuickBooks. If you receive the same error message, refer to Settings required for firewalls to make sure your firewall is properly configured to allow QuickBooks access to your company file.
  7. Open the company file in QuickBooks. If you receive the same error message, open a different company file or a sample company file located in one of the folders you scanned with the Database Server Manager.
    • If no company file will open, reboot the host computer and try again.
    • If other company files open without error, the company file generating the error message may be damaged. For more information refer to Verifying and rebuilding QuickBooks company data.
Jun 01, 2010 | Intuit QuickBooks Pro 2008: Windows
I want to back up a 2nd copy of a quickbooks pro 2006 file but it won't work. When i try and load it from the backup file on my hard drive it says that windows cannot open the file, and to use a program...
You need to make the backup from quickbooks using file,
backup. Select the drive you want the data stored on. Then if you need the backup data you need to use file, restore.
you are only backing up the data so you have to run the
file from the program, with the restored data.
Sep 19, 2017 | Intuit QuickBooks® Pro 2006 Full Version...
The connection to the company file has been lost Quickbooks must close immediately. Any unsaved data will need to be re-entered. My Company file is damaged and i have tried opening it on the another...
You will need to verify and rebuild your data file. Please follow the steps i provided, this will guide you threw the process.
Verify your data:
1. Close and reopen QuickBooks to create a new Qbwin.log file.
2. Choose Window > Close All, so that no company files or QuickBooks windows are open.
3. Choose File > Utilities > Verify Data.
* If you see QuickBooks detected no problems with your data, your data is clean. Click OK.
* If you see Your data has lost integrity, your data file is damaged. Run the Rebuild Data utility to repair the damage. You may need to run Rebuild two or more times to repair all of the damage. Rerun the Verify Data utility after each rebuild to verify that the errors have been corrected.
* If your see A data problem prevents QuickBooks from continuing, then your data file has a structural problem. Run the Rebuild Data utility to repair the damage.
Rebuild your data:
Important: If the company file is on a network drive, copy the file to a local computer before attempting to run this utility. Be prepared for this computer to be unavailable for several hours running the Rebuild utility. Never rebuild or update a company data file that is located on a remote drive (for example, by accessing it over your network).
If you can't open QuickBooks to run the Rebuild Data utility refer to QuickBooks does not open.
If you're unable to open your company file when double-clicking your QuickBooks desktop icon, see Opening QuickBooks when troubleshooting.
To rebuild the file:
1. Choose Window > Close All.
2. Choose File > Utilities > Rebuild Data.
3. Click OK to the warning message requiring a backup of the company file before starting the rebuild.
Important: Do not replace your current backup. Intuit recommends using a newly formatted external media source for this backup (such as a CD or DVD). If necessary, back up to your local hard drive.
If a message appears asking if you want to replace the backup file, click No.
To avoid overwriting the current file, enter a new name in the Filename field.
4. At the bottom of the QuickBooks Backup window, click OK.
Important: If the backup process fails, at the Rebuild prompt, click Cancel.
Do not continue the Rebuild process with your original company file if the back up process does not complete successfully. This can lead to permanent data loss.
You must make a copy of the company file and attempt the Rebuild process again using the copy of the company file.
Rename the copy of the company file with a unique name to avoid confusion with the original file.
5. The Rebuild Data utility starts as soon as the backup process completes. Click OK to the Rebuild has completed message.
6. Close the company file, and then reopen it to refresh the lists in the file:
1. Choose File > Close Company.
2. Open the company file:
* QuickBooks 2008 and 2007: Choose File > Open or Restore Company. Then select Open a company file and click Next.
* QuickBooks 2006: Choose File > Open Company.
7. Click the company file, and click Open.
8. Run the Verify Data utility.
Sep 22, 2009 | Computers & Internet
I have been getting error code -6000; -83. What
Might I suggest going to the Getsatisfaction website. I have provided a link that will direct you there.
http://bit.ly/7ebRo
You can use OpenID, Windows Live/Bing, or create a new username.
Hope they can help you out.
Jun 05, 2009 | Intuit QuickBooks Pro 2007 Full Version...
My QB crashes everytime I try to invoice...only with one company, but with others it runs fine. Problem is i need the giles from that one company, What do I do?
You should verify your data file (Click on file, click on utilities, click on verify data) If quickbooks doesn't find any problems, Back up your company to a different location and if your using 2006 or higher, create a portable file, close quickbooks, reopen quickbooks, and then click on open portable. When it prompts you to backup, click ok and back up again using a different file name.
You then need to go to templates, and (sorry to tell you this ) change each one to the default setting (click on lists, click on templates, the click on templates at the bottom, and click on edit, click on additional customization and then default. Then click save and close. Do this for all templates.
Also resort each list (item customer and vendor) to their original order.
Close the file and then reopen and verify data - if this doesn't fix the problem you will need to contact a pro advisor or intuit for aid in fixing the file
Jan 30, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Upgrading from Quickbooks Pro 2003 to Quickbooks 2009
I would not open up the company file in 2009. Open your 2003 Quickbooks, make a backup and then restore the back up in 2009. If you do run into problems you might want to upgrade into 2006 and then to 2009. (you will need to find someone who can do this for you if you don't have a 2006 version. I can help you with that if you need it
Jan 21, 2009 | Intuit QuickBooks Premier: Accountant...
Quickbooks pro 2009 error code: 00000 00000 shuts down quickbooks, can't get past this error for installation
  1. Open the company file in QuickBooks Pro for Mac 2009.
  2. Resort QuickBooks lists.
  3. Run the Verify Data Utility.
  4. Run the Rebuild Data Utility.
  5. Create a Back Up of the file:
  1. Go to the File menu.
  2. Select Back Up to QuickBooks for Windows.
  3. Save the file to the Desktop of the Mac.
6 Copy the file to a portable media.
7 On the PC, copy the file from the portable media to the Windows 8 Desktop.
8 Restore the backup into QuickBooks for Windows.
for more help visit QuickBooks Technical Support
Jan 08, 2009 | Computers & Internet
Quickbooks error codes
I did a back up from my laptop (Vista) to my desktop (XP) and now I have the error message (-6000,-301). Can you please help
Dec 11, 2008 | Intuit QuickBooks Pro 2007 Full Version...
Moving QBB data
cant u download the content of the floppy to ur laptop?
Jun 13, 2008 | Computers & Internet
Back up
open quickbooks and do a backup and save it to your desktop or whatever location you prefer. after this is complete open Nero and choose create data disk. browse to the location of the quickbook backup is located then click to add, you can add serveral backup files by click add and browse to the next backup. put your cd or dvd in the computer and click the burn button.
Oct 30, 2007 | Computers & Internet
Intuit QuickBooks Pro 2007 Full Version (299116) Logo
54 people viewed this question
Top Intuit Computers & Internet Experts
Scott Fair
Scott Fair
Dan Shibata
Dan Shibata
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
