Question about Excalibur Electronics Soundmaster Satellite Floating Wireless Speakers With Universal Dock Speaker System (145) for Ipod
I have an Excalibur SoundMaster,digital music system. instructions are MIA. I have my ipod on the docking station. pushing the function button will turn on music and after a minute it stops and shows charging. How do I keep it on?
Speakers bose docking station make a noise
Have two Bose docking stations and the oldest (white) one have some problems now. When I put in one of my iPods in the docking, the speakers make some weird, creaky noises. Kind of a sound, when I'm looking for a channel on the radio. When I wiggle a little bit the connector from the docking station, it will play some music for a short time. Still it is not the same quality sound, it used to be. Also, some times the sound is too loud and when I touch ONE time the volume minus (-) button, you can hardly hear the music, it is too soft. Hope somebody can solve this problem.
Sep 10, 2012 | Bose SoundDock digital music system...
My Ipod Touch doesn't fit in the Bose Sound Dock
The most cost effective bet is to fit a charge upgrade or a Bluetooth and charge upgrade yourself. It takes about five minutes. The complete kit is available form invebo.com and you don't need any special skills. click here to see the instruction video
Jan 01, 2012 | Bose SoundDock digital music system...
My connection is bad on my portable ipod docking station. goes in and out... has something to do with the little piece in the base. help.
Where the Ipod sits in the dock, there's a removable piece that you can pop out....that should take care of your problem.
Mar 13, 2010 | Bose SoundDock digital music system...
I pod charges, plays, but no sound
Easy, I had this problem too. The reason it isn't playing is because its not in all the way. I was getting very frustrated with this, so I kept trying to push it onto the dock to get it all the way down.
Solution:
1. Play a song on your ipod/iphone so you can hear it through the device.
2. Connect your ipod/iphone to the docking station(Bose) so that you hear the chime(This lets you know its charging).
3. Pick up the docking station and firmly press the ipod/iphone down on the connector.
4. Keep pressing it and wiggling around until you hear the music begin to play through the docking station.
It may take a few tries, but you will get it.
Hope this helped!
~ Jake
Oct 05, 2009 | Bose SoundDock digital music system...
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Bose sound dock - no sound comes through it but my ipod works with the ear plugs so it's not my ipod
I had this problem for the pat two days. Believe it or not I took my Ipod touch of the dock. Shut the power off to the Ipod to reset it. Also the power to the docking station. turned everything back on. Put the Ipod back into the docking station and heard the beep.. and hit play and it was working again. Not sure but shutting Ipod off does act like a reset.
Jul 19, 2009 | Bose SoundDock digital music system...
Bose docking station problem. Remote will not work on either my ipod touch or I Phone. The volume buttons work on the remote but the skip and pause/play buttons do not. The Bose is brand new and straight...
If it is brand new. It is under warranty. Go back to the store where it was purchased and tell them the problem. They should replace it with another new one. Have them show you how to use it on all of the functions on your Bose Docking Station. Make sure you tell them about the ipod Touch and the iPhone.
Jun 07, 2009 | Bose SoundDock digital music system...
Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Dec 09, 2008 | Bose SoundDock digital music system...
I can not figure out how to set the times, or the alarm for my new Clok Smooth iPod Docking Clock Radio - TCR368 manual. it did not come with a manual or instructions of any kind.
1. With the dock station off (none of the functions are highlighted) press and holdthe Clock/display and/or Play/Pause button.
2. After holding for up to 5 seconds (still hold) press the hour or minute buttons to adjust th ehour and minute
3. Once you are done, release your the clock/display and/or play/pause button
Nov 28, 2008 | Digital Products International Clok Smooth...
Bose docking station chip broke off
I had the same problem that the ipod would onl play when I pulled it forward in the dock. Looking closely, I saw that some of the pins on the left hand side of the connector were bent forward, so I bent them back with a needle:
(ie. pushing the pins to the right, as shown here). This solved the problem for me.
If your connector is too far gone, I suggest looking to:
http://www.chargeconverter.com/shop/connector.htm
for a new connector for £3-4 or
for a whole PCB (Printed Circuit Board) replacement for £10-15.
Hope this helps...
Nov 26, 2008 | Bose SoundDock digital music system...
Excalibur Electronics Soundmaster Satellite Floating Wireless Speakers With Universal Dock Speaker System (145) for Ipod Logo
57 people viewed this question
Top Excalibur Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Excalibur Audio Player and Recorder Expert? Answer questions, earn points and help others
