Question about Cameras
The computer isnt recodnizing it and its flashing red on the front, the battery icon that is displayed to indicate charging is not on the screen when its pluged in to the usb port
  • 65 Answers
Try rebooting the pc. It's possible the USB driver has encounter a problem. Have you tried it on another pc?
If you're trying to download pictures, you could use a flash card reader instead.
Posted on Jan 03, 2011
How long do i charge a tesco mp3 for?
from your Manual :
• The lightning flash on the battery icon indicates the battery is charging.
You should leave the player battery to charge for at least eight hours.
When the battery is fully charged the battery icon will display
http://ttselectrical.custhelp.com/ci/fattach/get/30238/1328900517/redirect/1/filename/MP-108.pdf
Oct 29, 2014 | Computers & Internet
Gateway NV5378u lap top, brand new battery installed and status says 100% charged. When I unplug the computer it shuts off as if there is no battery. Could the new battery be defective?
There are a few things to check. The LED lights can tell you a lot. This will tell you more about the battery:
  1. On the taskbar, double-click the power cord icon or battery icon to open the Power Meter dialog box. Note: If the power cord icon or battery icon does not appear on the taskbar, click the show hidden icons button.
  2. Press Fn+STATUS to view the power status box, which opens in the upper-left corner of the screen. The power status box shows the current power source, the battery charge level, and the power management mode.
  3. Look at the battery charge indicator (if applicable).
    • LED green - Battery is fully charged.
    • LED orange - Battery is charging.
    • LED blinking red - Battery charge is very low.
    • LED solid red - Battery is malfunctioning. Note: This LED only lights up when the notebook is connected to AC power.
  4. Press the battery meter button on the battery. The battery meter lights indicate the percentage of battery charge remaining.
  5. Wait for a Low Battery warning message to appear.
If your battery charge indicator displays what looks like an inaccurate charge, you may need to recalibrate the battery.
To recalibrate the battery as mentioned, try this:
  1. Connect the AC adapter and then turn on the notebook.
  2. As soon as it starts and you see a startup screen, press the F2 key.
  3. In the BIOS Setup utility, use the TAB key to select the Advanced menu.
  4. On the Advanced menu, select Battery Auto Learning, and then press the SPACEBAR to select Enabled.
  5. Use the RIGHT ARROW key to select the Exit menu. On the Exit menu select Exit Saving Changes, and then press ENTER.
  6. At the Setup Confirmation prompt, select Yes, and then press ENTER.
  7. The battery recalibration process begins and a screen opens showing you the progress.
  8. When the recalibration has finished, and the message "Press [Esc] key to exit" appears, press Esc. The battery charge indicator now displays an accurate battery charge.
Hope this helps!!
Oct 20, 2013 | Computers & Internet
My flash will just not turn on. I have a casio exilim EX-Z35
At back camera, have lamp flashes orange where to indicate flash is charging and to tell image will not recorded(disable). You will can not take another flash until that lamp is stop flashing orange to indicate charging is full. in other view, please check at lcd screen have appear flash icon.
click button play mode to display menu. change set flash to on if flash icon is not display
for user manual
User manual trobleshoot
May 09, 2011 | Cameras
No power will not trun on
Hello
Plug in the printer power cord into electricity to charge the battery.The battery might need charging if the On light flashes green it indicates that the battery is charging.
Switch ON the printer, the battery charging icon (lightning bolt icon) flashes above the battery icon on the printer screen to indicate that the battery is charging.
If the battery is charged and the printer does not turn on with the battery power, unplug the printer power cord, if it is plugged in. Open the battery compartment and remove the battery. Wait for about 10 seconds, and then reinstall the battery.
An empty battery should fully charge in approximately four hours when the printer is not in use. If the battery still does not charge in 4 hours,you should replace it
Good luck
Apr 23, 2010 | HP PSC 2210 All-In-One InkJet Printer
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
Battery indicator flashing red when running on battery or on main supply and battery is 75% charged
When your battery indicator is flashing Red, it usually means that the charger is defective.
Dell also had a recall on some of its batteries. To see if you qualify for a free replacement click here: http://www.dellbatteryprogram.com/
If you want to reset your battery utility follow these steps:
1. Let the battery run completely dead. (Make sure all your work is saved)
2. Fully charge battery (You may still have flashing lights but if you turn your computer on and enter BIOS you can see the charge level)
3. Once again run battery dead.
4. Remove battery and wait 5-10 minutes.
5. Replace battery and use in normal operation.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 03, 2010 | Dell Latitude D600 Notebook
Is there any such thing as charging my mps nextar MA933a via the USB port? I just get sleepy z's on the display when I connect it to my computer.
Here is what I found:
Connected the player to the PC with and without prior power on successfully
OSD first displays message “Starting…” then:
Icon appears on screen with a picture of a computer monitor to right and mp3 player icon to left
When mp3 player is communicating with computer or sending information, an appropriate directional arrow appears between the two icons; when transferring files using Windows Explorer, the arrow reverses direction appropriately; when there is no activity either way, a series of “Z z z” ‘s appear on screen
Battery indicator icon also appears to right – new AAA battery resulted in a fully charged icon upon startup; no battery whatsoever resulted also in a fully charged battery icon appearing
-Tha Mp3 Doctor
Feb 02, 2009 | Nextar MA933A MP3 Player
Red Flashing Icon
The icons from the left: 1. Power indocator 2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive. 3. Power Source indicator 4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Regards,
Dapid Candra
Dec 02, 2008 | Dell Latitude D505 Notebook
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
