Question about Sanyo Televison & Video
I have a Sanyo LCD TV that has sound but no picture. Checked power supply and replaced with a new power supply and still has no picture but does have sound . This is for a Model # DP42849 Thank you for any assistance
  • patmac2 Jan 07, 2011
    good job
  • patmac2 Jan 11, 2011
    Yes Thank You
    President:
  • 1,961 Answers
Hi,doe sthe screen of your TV lights up?during power on?if not then there might be a problem on the inverter board and the backlight lamp of the monitor .The lamp is a cold cathode bulb it requires a high voltage supply from the inverter board in order to light up.just like any other bulb this lamp has a limited life span more or less 2 years of continues lit.The inverter board is a high voltage board the power input of this board is 24volts DC and the output is 200volts AC.The terminal input of this board or connectors must be check because of high voltage corrosion and loose connections always happen that leads to the mal function of the display or screen failure just like what happen to your TV.
Backlight lamp is installed at the top and bottom of the screen you need to open the back cover of your TV to check up the lamp.(make sure to unplug the TV before proceeding)..check first the test point that I mentioned then post back for your findings then will proceed to further trouble shooting...GOOD LUCK!
Posted on Jan 04, 2011
2008 sanyo lcd tv DP26648 power turns on but no picture or sound
likely a mainboard or power supply capacitor issue.
if you have the soldering skills fix it, otherwise time to replace the TV.
If you can de-solder and solder in new capacitors make sure you are using high quality capacitors be very causious of capacitors purchased from auction sites.
Apr 30, 2014 | Sanyo DP26648-R 26 in. LCD TV
I have a sanyo flat screen it come ons and shows a picture after about 5 minutes or so the pictures goes black but you still have sound.
Hi:
Have the power supply checked for bad capacitors that are leaky and getting puffy on their tops, also you may have a bad inverter that needs replacing, there are also two capacitors on the inverter as well that does the same thing.
Sep 24, 2011 | Sanyo 42 in. LCD TV
I own a sanyo "26
Tv now have it on green LED power on for good and tv flashes of pictures only for few min,than dies and have sound left only?Yes,take the tv aparts.U have all the tools and understanding basic electronic also can do basic soldering work too?Check the tv power supply board,that the board where the power a/c cord plug into it.Check the tv power supply board carefully for dead and dying components parts call capacitors.These dying and dead capacitors parts most likely all of the times,will bulges up or puffing up onto it tops.Changes all these dying and dead capacitors parts components,will solved this problems 70% of the times.If the tv power supply board it is good and no dying or dead capacitors component at all.Than the tv a long board that call the LCD inverter board it is dead.This LCD inverter long board are to helping the LCD screen panel to have a backlight to produced a picture.The tv long LCD inverter board have no parts for sale indivitually,al way have to buy a refurbish whole long LCD inverter board for the replacement.Also if you have no tools and soldering skills to fixed the power supply board by replacing capacitors component parts indivitually too.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a long LCD inverter board for the replacement.
May 28, 2011 | Sanyo DP26649 26 in. TV
Sanyo lcd tv 20"has sound but no picture
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks! ! ! !
Apr 20, 2011 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
My 42" sanyo lcd has
Hello, a no picture with sound condition can be caused by several things inside your LCD TV. A power supply circuit with a missing voltage source could be one cause of the problem, an inverter circuit or HV circuit could be another. The best answer to your question is to have it checked out by a qualified tech. If you have a little knowledge of electronics you could try to repair it yourself, you can sign up for our great tech support where they can assist you on the steps to take to get it up and running.
Nov 06, 2010 | Sanyo 42 in. LCD TV
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Sanyo 42" LCD will not turn on!!!
Power supply board is dead.Buy a refurbish power supply board at Shopjimmy.com,Ebay.com for the replacement.
Mar 26, 2010 | Sanyo 42 in. LCD TV
Sanyo DP19647...power comes on but no picture on screen. Any ideas?
Main Power Board is damaged, you have to replace but it´s an expensive part maybe the best is to buy a new TV
Sep 05, 2009 | Sanyo DP19647 19 in. LCD TV
Sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Mar 01, 2009 | Sanyo DP32746 32 in. LCD Television
Televison & Video Logo
452 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
