Question about Whirlpool Refrigerators
I have a Whirlpool Model WBM39MW S/N JE729053.The freezer only gets as cold as the fridge and when I open the door the alarm,light and fan immediatly starts to pulse
watugot
  • 290 Answers
SOURCE: freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Posted on Oct 27, 2007
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
deby69
  • 16 Answers
SOURCE: whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Posted on Jan 05, 2009
  • 531 Answers
SOURCE: fridge warm freezer cold
you may have a defrost problem check to see if you have frost up in the freezer
Posted on Apr 13, 2009
Freezers high tempeture light is on and freezer is not getting cold
Door left open usually starts a defrost failure, the evaporator gets blocked with frost and the fan motor can't circulate cold air into the fridge section- while the freezer fan is running, put your hand in front of the slots where the cold air should be blowing in the fridge section- if you don't feel air flow, you have a blockage. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Kenmore Refrigerators
FRIDGE TO WARM MODEL ED22DWXTNOO
It's a circulation problem so either the fan in the back of the freezer(circulates freezer and blows cold into fridge) or the defrost element. If the element is faulty the rear ices up and air won't flow. If fan is faulty it's not blowing the cold air. Remove rear panel if no ice it's the fan if its full of ice it needs the defrost element(usually get termination sensor also depending on type) If you open the freezer door and hold in the doorswitch you should hear the fan running if its working.
Jul 08, 2013 | Kenmore Ice Maker Kit For Sears Whirlpool...
Whirlpool WBM39MW alarm when door opened
Just had one of these with the blinking light, fan pulsating and no cooling. The fault is the power supply section in the control module at the back. It is a 2uF 400VAC capacitor going open circuit. make sure you replace this capacitor with something equal or better rated - it is critical
Jun 17, 2012 | Whirlpool Refrigerators
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
Freezer is cold 0F and frige is warm 70F
cleaned it and door was open for a while. closed door and and an hour later alarm went off. alarm now flashing and alarm light still on. temperature now at 53. freezer 33
Feb 01, 2010 | Maytag MFI2568AE Side by Side French Door...
Whirlpool fridge freezer ARC 4030?
Look to have the control module repaired / replaced.
Hope this helps
Dec 02, 2009 | Whirlpool ARC4030 Stainless Steel Top...
Fridge side wont cool unless the freezer door is open
the little fan motor in the freezer is defective.  It may only be stuck.
Apr 01, 2009 | Whirlpool ED5VHGXM Side by Side...
Freezer has frost building and the refridgerator is too warm.
make sure the evaporator fan is working, open door and push switch in if fan works make sure opening from freezer to fridge is not blocked. if door was removed make sure light in fridge is shuting off if temp in fridge is in the 50 degree range your light switch is not being deactivated check spacers between door and hinge . sometimes when door is removed a spacer will fall on floor and light switch is not hitting door
Jan 26, 2009 | KitchenAid KTRC22EL Top Freezer...
Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Mar 30, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
118 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
