Question about Cisco 7905 IP Phone
My cisco ip phone 7905 series is rebooting continuously
the reason for this would be that it is not getting it's config from the CallManager (or CME router).
The steps in a phone booting up something like this:
1) DHCP for IP Address, and Option 150 for TFTP Server
2) TFTP to address provided by DHCP Option 150
3) Get config file, a(an upgrade of firmware may occur at this point)
4) Connect to Call Manager/CME as specified in config file
First check DHCP server to see if it is allocating an address to the MAC address of the phone
Second confirm if DHCP is providing Option 150 and that is the IP Address of the TFTP Server (typically one of your Call Managers)
Third check that the phone is correctly configured on CCM/CME. A common error at this stage is that the phone is configured with the wrong model type.
Call back if you get to that stage and are still having problems.
Cheers, Simmo99.
Posted on Jan 06, 2011
What collaboration capabilities are available on the new Cisco 2900 and 3900 Series routers?
According to my experience and knoledge: the Cisco 2900 and 3900 series platforms have collaboration feature parity with the Cisco 2800 and 3800 Series platforms, so all of the following collaboration capabilities and solutions are present:
• Cisco Unified Survivable Remote Site Telephony (SRST)
• Cisco Unified Border Element
• Time-division multiplexing public-switched-telephone-network (TDM PSTN) and private-branch-exchange (PBX) gateways
• VoiceXML contact-center gateways
• Cisco Unified Communications Manager (UCM) media resources (allowing conferencing, transcoding, and Media Termination Point [MTP])
• Resource Reservation Protocol (RSVP) Agent
• Cisco Unified Communications Manager Express (CME)
• Cisco Unified SIP Proxy
• Gatekeeper
Cisco 3900 Series Routers
Jun 25, 2014 | Computers & Internet
Cisco IP Phone 7945G
Use the professionals rather than "a comment".
Contact Cisco directly here: Cisco Technical Support IP Phone FAQ
Feb 01, 2018 | Cisco 7945G IP Phone
My Cisco IP Phone 7945G keeps rebooting after I did a factory reset. Is there a way to fix this?
According to Cisco, when initiating a factory reset procedure certain information from the IP phone is erased while other information is reset to the factory default value, as shown in the list below:
Information Erased:
  • CTL File (Certificate Trust List)
  • LSC File (Locally Significant Certificate)
  • IP Phone Call History (Calls Received, Placed, Missed etc)
  • Phone application
Information Reset to Default:
  • User configuration settings (ring tone, screen brightness, sound levels etc)
  • Network configuration settings
t is highly advisable to follow the firmware upgrade procedure in a non-working environment to ensure other phones are not affected (in case of an accidental reboot), and to avoid the freshly factory reset ip phones obtaining the working environment's settings.
Please use the link below and follow the instruction http://www.firewall.cx/downloads/cisco-tools-a-applications/cisco-ip-phone-a-ata-firmware-downloads.html
Aug 28, 2012 | Cisco 7945G IP Phone
Can i make calls with a Hide ID? cisco ip phone 7960 series
You will need to configure this through whatever SIP gateway you are using, it is not configured through the handset.
May 23, 2011 | Cisco 7940 IP Phone
Cisco ip phone 7912 is not working. when conecting in LAN then it will not boot, while another same series ip phone on that LAn port works perfectly. Only red and green LED blink continue in...
If it is getting an IP address, goto that IP address and there you will be able to see some console messages. See if alternate TFTP is set and is going to a different CM server. If so change it to the ip of your CM.
Aug 17, 2017 | Cisco 7912G IP Phone
7940G IP Phone: how to solve the protocol application invalid prob...
Hi
This happens when you IP phone communicated with the Voice vlan with the IP address of data vlan.
To solve it manually enter the IP address of the TFTP server and option 150 on the DHCP server.
remove the voice vlan from the switch port and reboot the phone
again add the voice vlan and reload the phones
May 17, 2010 | Cisco 7940G IP Phone
Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
  1. Press Settings.
  2. The Network Configuration lock symbol must be unlocked. If not, exit to the main window and press ** # again.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) to Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
May 18, 2008 | Cisco 7910 IP Phone
Blank Screen
I would verify what the firrmware is of the phone. It is possible that the phones need to be upgraded.
Mar 27, 2008 | Avaya 5610 IP Phone
My Phone is on Busy Mode
Are you in a Call Manager envirnoment ?
Jun 11, 2007 | Cisco 7912G IP Phone
Cisco 7905 IP Phone Logo
410 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
