Question about Zebra Eltron LP 2824 Thermal Printer
The printer suddenly prints numbers instead of barcodes. Is the problem with Quikbooks or the printer? How can I correct it?
  • 77 Answers
Could be a problem with the printer driver. Try shutting down the printer and the computer. Then turning both back on. Sometimes printer drivers do weird things, If this does not work you may need to remove the printer driver completely and reinstall.
Posted on Jan 04, 2011
Can i print barcode from pr2e matrix printer?
With a matrix printer it may be easier to scan the barcode as a .jpg picture, then print the picture, which will include the bars and the digits
Mar 18, 2014 | Olivetti PR2E Matrix Printer
Error 616
The software is not corrupt. The 606 is basically telling you that one of the dots that heat up to make the image on your paper isn't able to heat up correctly. Since the printer can typically shift these dots over from one side to the other to help compensate for these dots going bad, it is also saying that it can't shift either.
You're seeing this issue on a barcode, and instead of a barcode you're getting a gray box. If you're unable to make changes in your code that is going to the printer, that tells it what to print and where, your best bet is to purchase a new printhead form Avery.
1-800-543-6650
Though the issue can be worked around, it is possible that now that you can print that barcodes you want, you may find that new ones won't be able to print because they're printing in that same space where the printer cannot shift dots to compensate for the bad one.
Jul 10, 2012 | Monarch 9855 Thermal Printer
I have godex 1100 barcode printer which is not working. It doesn't print barcode. it responds the print command from the computer and tries to print but halt immidiately blinking status light. It gives...
You did not tell us, whether it is not printing barcode's alone or no text is printing.
You might hear beeps for 2 reasons, Sensor posistion is not correct. or ribbon is not correctly fitted.
Kindly check both these. hope this will solve your problems.
If you have any other queries with barcode printer kindly mail/call us.
Regards Trridev Labelss Mfg Co Web Marketing Division www.trridevlabelss.com email Kirubakaran.rv@gmail.com trridevlabelss@gmail.com
Manufactures of Self adhesive labels and resellers of barcode printers and scanners and ribbons
Sep 14, 2010 | Argox X-2000+ Thermal Label Printer
CODE128 barcode problems
The printer of the number under the barcode is an option when you define the barcode. check in your programing manual.
Concerning the size of the barcode 128 . This is determined by:
- Print head resolution in your case each bar is 0.125mm thick
- The other bars are a multiple of this thin bar. This is the only constraint
Apr 20, 2010 | Toshiba TEC B SX4T Printer
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
We have a 9855 Monarch barcode Printer. We are
If the printer display just shows Ready, but doesn't print, there could be a few things wrong.
1 - no data is going to the printer
2 - data is going to the printer, but it is not the printer's native language
3 - cable connectivity issues
4 - wrong cable is being used
5 - if wireless, data is not going to the correct IP
If using a 3rd party application, make sure that you've chosen the correct Monarch printer, as well as printing to the correct port. Sometime people print to LPT instead of Serial, as an example.
If using 3rd party drivers, make sure of the same thing.
To see if the printer actually works, press both of the arrows on the display, at the same time, after the printer is at the ready screen. As long as have the printer configured correctly (ribbon, supply type, etc.), the printer should print out a couple of labels.
Oct 26, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Quikbooks Premier 2009 won't print on Vista 64. Printer setup doesn't open.
Try going to quikbooks website to download printer driver for Vista 64
Sep 22, 2009 | Intuit QuickBooks Premier Nonprofit...
Ladder orientation barcode printing bad resolution needs correcting
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
Apr 13, 2009 | Zebra Z6M Plus Thermal Barcode Label...
Datamax I 4208 prints slow when set to landscape
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
Jan 21, 2009 | Datamax M-4208 Thermal Label Printer
Zebra Z4m Barcode printer
That using these symbols. Select a better code 128A or B.
Aug 18, 2008 | Toshiba TEC BSX5 Thermal Label Printer
Zebra Eltron LP 2824 Thermal Printer Logo
82 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
