Question about Canon PIXMA iP90 Mobile Printer
I have not used my printer in 3 years. I just put a new color ink cartridge and the printer goes thru all the motions but does not print. Why??
  • 77 Answers
The ink in the rest of the print mechanism is most likely dried up.
Posted on Jan 04, 2011
New ink catriges, ink is not flowing
This issue can be caused by several different reasons.
  • First, verify the tab protecting the ink from dispersing is not still on the cartridge.
  • Verify the the ink cartridges have been inserted properly.
  • If a lever has been changed from its original position allowing the ink cartridges to be added or removed, ensure it is back into its original position.
  • Perform a head cleaning on printer if available.
  • Verify no software errors are occurring abd print a test page.
  • If you are installing non manufacturer authorized ink, attempt to use the manufacturer's ink instead.
  • If any indication lights are flashing or are different, refer to your printer documentation or printer manufacturer's web page for additional information on what the lights are indicating.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 02, 2013 | Canon PIXMA iP90 Mobile Printer
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
My deskjet 3745 wii not print with new ink. The cartridge shows full and the printer goes thru all the motions. The final print is no color and light black
Use the HP software (installed when you installed the printer) to run a "print-head-cleaning" cycle -- you've got lots of ink, but the print-heads are CLOGGED.
Aug 24, 2010 | HP DeskJet 3745 Printer
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
Epson Stylus 1520 won't print black
when you replace a cartrige make sure you take off only the yellow tape .. if you take off the white tape also then the cart wont work anymore .. careful about using off brand ink .. i used the cheep stuff for about a year before they changed the formula without telling me .. it clogged the heads completely .. .. nice wide format printer .. hope you get it working ..
Oct 01, 2009 | Epson Stylus 1520 InkJet Color Printer
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
Put in new cartridge and unit will not print. Goes through all of the motions but doesn't print. Printed many pages before "low on ink" message. Why does it not print now?
It may be caused by some issues. Check:
* Did you remove the plastic from the connections from the cartridge as the instructions indicates?
* Is the cartridge connector from the printer ok?
* Is the cartridge correctly installed?
* It's a new cartridge? I mean, NEW. Not refilled one or a cartridge that expired two years ago.
* Try running one or two "Clean printer head" procedure to see if ink flows.
Good luck !
Sep 04, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Epson Stylus CX7400 Ink Light Problem
You need to open up the maintenance window and go thru the motions that you are changing the cartridges and this resets the ink levels back to full and sends data to the printer saying that they are full and the ink light disappears and it prints fine !!!
Just changing them doesn't seem to do the trick like on a lot of printers
Jan 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Lexmark x1240 will not print
did you tried to set the properties to mono ?
Apr 12, 2008 | Lexmark X1240 All-In-One InkJet Printer
"Printing" fine, but no ink is output.
Same printer model with same problem as previously listed, printer goes through the motions but "no ink on page"!
Feb 04, 2008 | Compaq Inkjet IJ650 Printer
Canon PIXMA iP90 Mobile Printer Logo
425 people viewed this question
old marine
old marine
