Question about Galaxy Radios DX-959 40-Channels Base CB Radio
Radio won't stay on unless I tweak the case on the side of th mike any thing come to mind
    Novelist:
  • 500 Answers
Voltage regulator is broken from the case. have it re soldered.
Posted on Jan 06, 2011
I need to REMOVE the radio, how do i REMOVE the radio from a 2006 dodge sprinter cargo van?
you need a removal tool. go to the dealer. it is not cheap tool. look at spending $10 to $40 for the tool I spent $89 for the tool for a VW radio. They know they have got you, no tool no removal unless you go the chainsaw route.
Sep 01, 2014 | Kenwood KLH-126 Nylon Case, Black, Fits...
Radio displays kill and only receives does not transmit beeps when mike is keyed
Are you out of legal transmit band? Power source inadequate to maintain voltage on transmit.
Oct 22, 2013 | TYT Electronics TYT TH-9000 VHF...
Took radio out now truck wont start.security light stays on,won't flash at all. tried deactivating passlock can't, also domelight,hd lights,l/door lock, keyless kemote not working. all this fr
Ypur security system is armed, if you was try unlock procedure from owners manual and wont work, its possible that you will need visit your dealer to reprogramming.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 24, 2012 | 2002 Chevrolet Silverado 1500
Sterling frameless bypass shower doors inside door wont stay closed even though have it on th best option setting to do so
Some times it's possible to tweak a roller track (barely bend) at the proper spot to prevent the roller from back tracking past that spot.
Sep 17, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
My car radio push button switch is broke and the radio stays on unless the car is shut off will this drain the battery . If so is there a fuse for the radio that can be taken out?
As long as it goes off when you switch off the engine, it won`t drain the battery. If it stays on, it means it it is connected directly from the battery and yes.. it will drain it.
Aug 24, 2010 | 1998 Ford Escort
99 gsxr 750 losing power after 10k rpm if you have
The carburetor jets, there are 3 bands; A low, mid range and high range rpms. 10k would fall in the Mid range power. I would let the bike warm up a little bit and tweak the middle knob on the left side of the bike and keep in mind you need the right mixture so turn it quarter turn one way at a time per testing the mid range rpms while riding, tweaking 1/4 turns in between tests. If it gets worse, turn it the other direction until you find that sweet spot in the mixture of fuel/oxygen. The carburetor jets, there are 3 bands; A low, mid range and high range rpms. 10k would fall in the Mid range power. I would let the bike warm up a little bit and tweak the middle knob on the left side of the bike and keep in mind you need the right mixture so turn it quarter turn one way at a time per testing the mid range rpms while riding, tweaking 1/4 turns in between tests. If it gets worse, turn it the other direction until you find that sweet spot in the mixture of fuel/oxygen. The carburetor jets, there are 3 bands; A low, mid range and high range rpms. 10k would fall in the Mid range power. I would let the bike warm up a little bit and tweak the middle knob on the left side of the bike and keep in mind you need the right mixture so turn it quarter turn one way at a time per testing the mid range rpms while riding, tweaking 1/4 turns in between tests. If it gets worse, turn it the other direction until you find that sweet spot in the mixture of fuel/oxygen.
Mar 07, 2010 | 2007 Suzuki GSX-R 600
Set back thermostat has mind of its own.
The Honeywell Vision Pro 8000 can be complicated to figure out if it isn't set up right from the system menu. There are so many things that you can make it do, sometimes the most common things are wrong. My question is ''what kind of system do you have, heat pump or not?, and is the system gas or oil?" If I knew these things, I could definitely help you figure out if the thermostat is set up right. I have the manual so that I can give you exact numbers. Just in case, you can email me at : kingbrizzle@aim.com
Feb 06, 2010 | Honeywell Programmable Thermostat Heater
I have a cobra 148gtl with 5 pin side plug for mic.Im trying to wire a superstar dm 1000 echo mic to it,red,yellow,blue,white,& unsheilded wires dont know were they go.???????
ALLways start with ground. Find ground on radio pin with ohm meter. EVERY thing operates off ground. Once you find ground on radio....solder your ground wire on mike cord to corresponding # on mike jack. Once you have ground on proper pin then all else is elementary......use ohm meter to see which wires are TX and RX on mike.....last wire is audio wire.
Jan 20, 2010 | Cobra Radio Communications
Power turns on and off...smells like something is burning
Make sure your red speaker leads are not touching the case or the black leads. Check to see if anything metal fell into the unit through the vent like a staple or piece of wire. Pick it up side down and shake it. It is possible for a foreign body to get "welded" on a short so take the case off and do a visual inspection. Look for burned components. Unless you are electrically savvy, this would be a good time to take it to a repair tech or a friend. Good luck ;)
Jun 20, 2009 | JVC TH-M505 System
Viewsat Ultra USB port
Ultra could be clone.
Dec 17, 2007 | Belkin (F5U304)
Galaxy Radios DX-959 40-Channels Base CB Radio Logo
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
