When it get's really windy our pilot light get's blown out, we have a mobile home and want to know if the chimney should be raised
    Novelist:
    Scholar:
  • 111 Answers
That's certainly a possibility, and there are caps/baffles you can add to the top that may divert wind as well.
But are you certain it's wind coming down the pipe? Make sure you don't have any other drafts that are making it into the unit at another location. If it's really windy and you cover the top does the flame still flicker at all? You might want to check that before you put in time and expense on raising the height and/or adding a rain/wind difuser on top... just to make sure. I lived in a mobile home a time or two, and they're notorious for those little gaps and leaks.
8^)
Posted on Jan 03, 2011
I have 1974 beach furnace in my mobile home. It ran two years 100% trouble free. When we went to turn it on in August, it would stay lit until reaching temp, then quit. I can get maybe 3 cycles before I...
Though not familiar with 'beach' brand mobile home units, they are probably a 'barrel' design similar to the coleman and intertherm furnaces specifically made for this application. That said, have the specialists check for a cracked heat exchanger? A crack in the right spot can cause the pilot to be blown out by the blower after the main valve shuts off. Just a thought.
Dec 07, 2014 | Heating & Cooling
I had problems with my chimney with natural gas and wondering what I need to do was told ventilation not up to code and chimney violation... concerned with this since my home gets really cold
You should have a professional Chimney technician inspect your chimney. If there is a venting/draft problem, you could be pumping Carbon Monoxide into your house and could be asphyxiated.
Nov 13, 2014 | Water Heaters
A back draft causing the kitchen to fill with fumes?
You need to clean your chimney pronto.
Feb 14, 2014 | Televison & Video
I can hear the wind blowing extremely noisy from my gas fire /chimney
It is not likely blowing from the fireplace, rather your hearing outside wind noise through the chimney pipe.
On windy days this is normal.
The noise can only be limited by the flue pipe damper and the length of the pipe.
Apr 14, 2013 | Heating & Cooling
Gas water heater smells of vent backflow and has residue on top of unit
have the chimney checked for bird nests etc.(cleaned)
Aug 27, 2017 | Water Heaters
I have a 3 year old ge smartwater gas water heater. in our ontario winters, the gravity vented unit spills exhaust into the basement because the pipe and chimney get too cold after the heater is off for...
Id try raising the chimney until you can get the smoke from a piece of paper to get sucked up under the draft hood. I believe theres a different problem then a cold pipe.raising the chim.might not be the answer.
Jan 17, 2011 | General Electric GE SmartWater Household...
Hi, I am a caretaker in a 12 suite apartment block. The building has an old gas-fired hydronic Weil McLean boiler (maybe 10-20 years old). The gas pilot switch was regularly flipping (about 2 times at...
IS ANYONE CHECKING GAS PRESSURES? A BLOWING PILOT COULD BE UNSTABLE AND LIFTING OFF.IF IT IS WIND RELATED TRY A PIECE OF TIN FOR A "WIND SHIELD" AROUND THE PILOT
Jan 05, 2011 | Heating & Cooling
Downdraft problem. I live in a rowhouse with a
For one thing your pilot light shouldn't blow out because of a downdraft. They are not strong enough to blow out a properly working pilot.
Have the thermocouple and orifice cleaned out. The orifice hole is sooooo small you won't be able to put the thinnest gauge needle through it. Any residue buildup results in a weak flame that is easily blown out.
Extend your chimeny simply by adding a double wall flue to it. Then put a cap on it.
Nov 04, 2009 | Heating & Cooling
Intertherm furnace problem?'s
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
Oct 27, 2007 | Intertherm P3RA-048K Air Conditioner
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
