Question about SanDisk Sansa e250 MP3 Player
Sandisk 250R my sansa overheated and then the screen turned white with black spots it will still play music but wont display anything i updated the software and took out the battery for an hour but it still wont work
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
White screen after being plugged in to charge
when it goes to sleep all you have to do is switch it on and it should come back to the original state but you can also do a factory reset which will delete everything but thats only if you are really desperate
Jul 08, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa problems!!!
i recommend that you open it up and see if any connections are loose
May 07, 2008 | SanDisk Sansa E280 MP3 Player
Wont work..
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Should you have any problems after you update the firmware let me know and I will be more than happy to help you...
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Mar 29, 2008 | SanDisk Sansa E280 MP3 Player
Sansa MP3 Screen is white - display not working
1. Try resetting the player if it has a reset button
2. Drain the battery by leaving it on for an extended period until the screen in blank and no sound comes out of your ear buds. Then connect to AC adapter or computer and charge.
Feb 27, 2008 | SanDisk Sansa e260 MP3 Player
My Mp3 wont play certain songs
Sounds like you have two problems here. First my guess is your files bought from walmart are corrupted some how. just delete the ones that are giving you fits and call it a day. Second you mentioned it wont even sync music,,,, Are you saying none of your music or just the walmart ones ?
Nov 17, 2007 | SanDisk Sansa e260 MP3 Player
Certain songs wong work
get a refund. It needs to be relicened on the net
Nov 09, 2007 | SanDisk Sansa e260 MP3 Player
Sansa screen
break something under warantee and send it in
Apr 27, 2007 | SanDisk Sansa e250 MP3 Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
