Question about Whirlpool Duet GHW9150P Front Load Washer
My washer makes a groaning noise when spinning. any advice on what the problem might be?
  • Whirlpool Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Posted on Jan 04, 2011
WHAT CAUSES GROANING NOISE WHEN SPINNING?
Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 11, 2014 | Bosch Washing Machines
Whining noise from kenmore elite washing machine during spin cycle
it is poss. the bearings are going. if you can spin the drum by hand and it makes the noise it is the rear bearing...
May 06, 2014 | Kenmore Washing Machines
Making noise when spinning
bearing going bad, ride it until you cant stand the noise then get another machine, not worth changing the bearing
Jan 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
The washer fills and agitates, and spins, but when it is stopping the spin cycle it makes a really loud groaning noise and my tenant says there is a rubber smell.
The brake shoes are not grabbing like they should, the rubber smell is the motor coupling. This is putting a load on that coupling and will soon cause it to fail.
Nov 18, 2010 | Frigidaire GLWS1233A Top Load Washer
I have the same groaning noise with my dish washer GSD2200G02WW
Remove both spray arms, and try a cycle with the washer empty.
If the noise changes or dissapears - replace one spray arm and try again. Replace the spray arm that creates the noise.
If there is no change, then replace the drain pump.
May 02, 2010 | Dishwashers
Won't drain. Won't spin.
Sounds like there's a blockage in the drain hose, or the pump. There could be a coin jamming the pump impeller. If the clothes are wet it's got to be a drainage problem...Good luck....Nomess
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kemore 110.26912690 will agitate won't spin, makes noise
You need to replace the coupling that goes between the motor and transmission
Jul 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore HE2 Elite is making groaning noises and then error messages 5D and/or F
did you clean pump out by removing acess port on front end of pump? also you can ckd pump impeller by removing screws around pump body impeller will free wheel but should have some resistance to turning by hand if no water in tub reinstall pump put in drain spin to see if drum will spin if it does forget main motor ..motor is most reliable par on those washers
Aug 06, 2008 | Kenmore Elite 45986 Front Load Washer
Groaning noise in Maytag 4000 washer
yea probly passed warr from manu , if its rear bearing issue gonna run alot ot fix BIG JOB!
Feb 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
439 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
