Question about Garden
What type of blade fits saw. have no manual - Garden
  • 8,197 Answers
May I get the make and model # to help you more
Posted on Jan 03, 2011
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
Is there an easy way to put the blade in a scorpion saw
Here is a link to the manual for your saw.
https://www.manualslib.com/manual/17171/Black-And-Decker-Ks629-638se.html?page=7#manual
Place the blade with the
tooth protector fitted
over the location pin. The
blade teeth should be
facing the handle.
Rotate the blade through
90 until it is fully located
in the slot and the
location pin is in the
locked position.
To ensure the blade is
securely fitted try to
remove without pressing
the blade release button.
Remove the tooth
protector, your saw is
now ready for use.
Note: If you are unable to fit the blade, check if the
location pin is in the correct position as shown
below. If it is not, keep the blade release button
depressed and use a screwdriver to turn the location
pin into the correct position
Feb 13, 2017 | Blade Saws
Are there any other rand of saw blades that fit a Delta 40-130 scroll saw? I understand delta blades are obsolete and can't even find the part number For reference. It is a pin type
i see scroll saw blades all the time at menard's and home depot.but if you search amazon.com they have lots of items and just may have them
Mar 21, 2015 | Delta Saws
How to fit blade in performer 350w jigsaw
There is a blade release that you have to push up while inserting blade. If this isn't the problem, there are many types of blades for different jigsaws. You need the one for your brand. Take an old blade with you when you purchase. Good luck
Oct 18, 2014 | Saws
Lost my manual. Need to know how best to switch blade
There is t shaped scocket type wrench that came wuth the saw that pushes into the saw next to the rear handle it fits the bolt that holds the blade on.There is l shaped metal locking buttom on the front of the motor houseing. The bolt has left handed thread so it loosens in the oppisite deriction as a normal bolt clockwise. push the L shaped button in to lock the blade loosen the bolt remove the washer and blade install new blade in reverise order
Dec 22, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
I have a Craftman scrooll saw, it came with pin end blade, but I want to use plain end blade and I don't know how, this machine only came with end pin blade.
Without model number of saw hard to tell. If yours in fact requires the pin, that's what you'll have to use. One usually buys the blades to fit the saw, not make the saw fit the blades.Your manual should tell you what kind of blades you can use in your saw. If you don't have that you can get one from www.searspartsdirect.com. Search for parts for your saw, then click over on the right side for manual. GOOD LUCK!
Jul 23, 2010 | Craftsman Saws
Need to fit a tall cornice on a new kitchen but my sliding mitre saw splinters the cornice
You need much smaller teeth and pitch for softer materials. Hardware stores have a list of types of blades for Stone, wood, plaster, laminates, etc. Your service manual for the saw should have this info also, as it depends on the diameter of the saw as well. If all else fails, new blades are printed with their optimum use, check each one in a self serve store.
Cheers.
May 06, 2010 | Saws
How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
May 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
B&D 7580 Type 5 jigsaw. Cannot install blade
take your saw to any hardware store and they will sell you a blade that fits your saw and show u how to change the blade. not all blades fit all jig saws.
Apr 15, 2009 | Saws
My husband has a BLACK & DECKER JS515 VARIABLE SPEED JIG SAW WITH QUICK CLAMP 3.5 AMP which i accidently broke the blade on...i cant figure out how to change the blade..any help would be greatly...
Here is a link to the instruction manual, and just under the place where it says Save These Instructions it tells you how to change the blade.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90520882,JS515.pdf
Fitting the saw blade (figure A)
- Hold the saw blade (9) as shown, with teeth facing forward.
- Push the lever (3) downwards.
- Insert the shank of the saw blade into the blade holder (10) as far as it will go.
- Release the lever.
There is a little lever where the base of the blade fits into the holder that you depress to release the blade...You can see a picture of it in the manual.
I hope this answers your question...if so, please take a aec to rate this post...thanks.
Mar 23, 2009 | Black & Decker Single Speed Jig Saw
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
