Question about Dewalt Drills
DE759 Dewalt drill/driver. Removed screw inside chuck but unable to remove chuck?? What do I do?
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
  • 12 Answers
SOURCE: Dewalt Drill DC728. Chuck came out of drill body
If you find that the end of the screw inside the chuck is actually broke then you have a gear problem inside your drill. This is actually a very common problem. Sometimes people push too hard on their drills and the gears inside wear out and break. This prevent the motor from wearing out, but, the gears have to be replaced.
If it is the gears and not the chuck. you broke the minimium of the front gear or gears inside your drill. YOU CANNNOT repair gears. they need to be replaced. you may be able to find some off brand gears to work but, you run the risk that they are not as strong as your original ones, or may not be exactly grooved correctly.
so, if replacing your chuck does not work. find replacement gears. IF you cannot find the gears from the manufacturer see about replacing your drill.
If the chuck is still good, keep it. If you buy the same model, keep your old drill for replacement parts, ie, switch, armature, cord, etc.
hope this helps somewhat.
Posted on Jun 11, 2009
rowdy45176
  • 2176 Answers
SOURCE: how do you remove a key chuck from a dewalt drill
first shift the drill to the drill only position and the gear selector to the low position, remove the chuck retaining screw LH thread, find a bent handle allen wrench about the chuck capacity and lock in the jaws of the chuck, put the chuck on a block of wood at about a 30 degree angle to hit the long portion counter clockwise and strike it with a hammer, it might take a couple hits but it will come off. I misread the header last time.
Posted on Oct 07, 2009
SOURCE: removing the dewalt DC925 'rohm' chuck
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Posted on Oct 18, 2009
mark24354
  • 776 Answers
SOURCE: How to remove a chuck from a DeWalt hand drill
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
Good luck.
Posted on Mar 19, 2010
How do I get the chuck off of my DeWalt DW 117 1/2" VSR Drill Serial #1229?
Open the chuck jaws and look down inside the chuck. You will see a screw head that is holding the chuck to the drill. Once you remove the screw, the chuck should pull off easily.
Jul 31, 2014 | Dewalt Drills
Problem with the Dewalt 3/8"VSR
My solution when the other mentioned ideas didn't work was this: I removed the 7 Torx #20 screws ( a common screw driver will work as well) and removed the housing half to expose the shaft. The chuck shaft bearings and gear lifts out as one assembly. Directly behind the chuck there is a half inch section of shaft exposed. I mounted a vise grip on the shaft (won't hurt it) and clamped the affair in a bench vise. With a 5/16" allen wrench mounted in the chuck and using a mallet I spun the chuck off with a solid smack counter clockwise . Very simple and easy .
Aug 29, 2011 | Dewalt 3/8"VSR 6AMP CORDED KY DEWALT DRILL...
Remove dewalt chuck that is stuck
down inside the chuck head itself is a allen head screw,, it has reverse threads on it. if you have already removed this screw and the chuck is still stuck then you will need to use a small gear/pulley puller to get it to release.
(( note: if you do not have access to a puller -- stop by you local Dewalt repair shop and I am sure that they will pull the chuck off with their puller at no charge to you )).
c...
Jan 05, 2011 | Dewalt 18 Volt Compact Drill Kit
Drill chuck
I think that if you open the chuck as wide as poss there is a screw up in the inside if the chuck thinkk its a slotted head screw undo this and chuck will come off
Jul 23, 2010 | Dewalt 18 Volt Compact Drill Kit
How to remove the chuck?
open the chuck fully and it shoudl have a screw inside. Unscrew it, but be carefull, these screws are usually reversed - to uncsrew, rotate it clockwise. Once done, put allen key into chuck (short side in), fasten the chuck to hold allen key well and hit the key with hammer - counterclockwise direction. You might want to verify this procedure with someone else as I have no experience with Dewalt, but this way it works for Makita, Metabo, Narex, ... then why not for Dewalt? Juraj
Jun 06, 2010 | Dewalt DC727KA 3/8" 12v Cordless...
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
How to take my chuck off broke tool off inside chuck
The screw that holds the chuck on, is in the bottom of the chuck itself. If there is something jammed in the chuck, it must be removed in another manor. If the chuck is jammed, I have used two pair of channellocks to open the it.
Oct 07, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
