Tv wont turn on, after unplugging it, turning off the breaker, unplugging the outlet, changing batteries to remote. Won't turn on on the tv panel or remote. tv technician won't be in for another week, and its too far away to drive to. how do i repair it myself?
  • Minner Jul 10, 2008
    can i do it myself?
    Champion:
  • 217 Answers
There should be an internal fuse, which is probably blown. Should also be an easy fix, if that is the case.
Posted on Jul 09, 2008
Philips digital tv won’t turn on.
unplug from electric, wait 30 seconds, plug back in. Check that you have power at the outlet (fuse/breaker shut off?) If it has a power word which plugs into the TV as well as the wall, be SURE it is tightly attached to BOTH. Make sure you aren't blocking the remote control receiver (you can turn most TVs on/off on the TV itself -- look for a power button). Be sure your remote has fresh batteries. Good luck!
Jan 14, 2018 | Philips Televison & Video
Why wont my Tv turn back on after the electricity went off?
Did you have your television plugged into an outlet with a surge protector? Does it do anything when trying to turn it on? Might have fried it when power came back on or when elec. went off.
Feb 05, 2015 | Emerson Televison & Video
Television
Try unplugging it from the outlet for a 5 minutes, and try again. If that doesn't work - try plugging in a lamp to the outlet to make sure it works. You can also try connecting the TV to a different outlet (check fuses or circuit breakers). If you use a remote - change the batteries - or try using the power switch on the TV itself.
If it doesnt work - provide the brand and model of your TV.
Apr 11, 2014 | RCA Televison & Video
TV will not turn on
Check the wall outlet, make sure there is power at the wall. If not, check the breaker panel. If there is power at the wall, check the TV for a manual on/off switch. If you have a power switch on the TV, turn it off, wait 10 seconds, then turn it on. If no power switch on the TV, unplug the TV for 10 seconds, then plug in again. Use the remote to turn the TV on. Check for a fuse or circuit breaker on the TV, usually near where the power cord enters the TV.
Make sure you have good batteries in the remote. If all this fails, then something may be damaged inside your TV, as a result of a power spike before the power went out, or when it came back on.
Take it to a repair shop.
Apr 07, 2014 | Magnavox 19me601b/f7 19-inch 720p Lcd Tv
My RCA HDTV wont turn on can u help
HI Kenya - Have you checked to make sure that the outlet your TV is plugged into has power? If not, unplug your TV and plug something else in to see. If there is no power, then you have an issue with your circuit/breaker box. Have you tried your remote control (will charged batteries) and tried turning it on manually from the front of the TV? If you've tried all of these things and they are fine, then it is something internally wrong with your TV. Unless you are willing to take it apart and figure out, you will need to take it for repair or replace it. I am sorry, but there is no simple solution without knowing more detail about it.
Nov 30, 2012 | Televison & Video
TOSHIBA 32AV502 Wont Turn On
Ensure that the input device and the connections are ok. Try changing the input device to something that you know, works. Try controls on the panel of TV. Remove battery from remote, before you do that. Try connecting the TV to a different power outlet. If nothing works, this might require the attention of a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
I bought LCD TV 32"
Check to make sure that the power cord is plugged in. If it is, plug something else into that outlet to test and make sure that the outlet works (use a lamp or something that you know works). If the outlet doesn't work, check your breaker box for a popped breaker. If the outlet works, and you are sure the power cable is connected properly, then you need to return the TV to the store where you bought it. Most retailers have at least a 30 day return policy for defective merchandise.
Apr 03, 2011 | Televison & Video
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
No power
If your television has no power, try the following:
1. Check the power cord for breaks, tears, or exposed wires .
2. Check to be sure that the power cable is fully inserted in the outlet and that the outlet is working.
3. Go to your fuse box or circuit breaker box and check the fuse or circuit breaker of the circuit your TV is plugged into. Replace the fuse or reset the breaker if necessary.
4. Replace the batteries in the remote control, and then try turning on the TV using the remote.
5. Unplug the TV, wait five minutes, plug the TV back in, and then try turning on the TV.
If the recommendations above do not resolve your problem, most likely the power supply in your TV has failed and your television needs service.
Thank you !!
Jun 04, 2010 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
61" samsung won't turn on???
If your television does not turn on, try the following:
If the recommendations above do not resolve your problem, most likely the power supply in your TV has failed and your television needs service. To begin the service process.
Sep 01, 2009 | Samsung HL-S6187W 61 in. HDTV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
