I have an AKAI X-1810D tape deck that does not auto reverse with the sensing tape in place on the tape. Also, is a repair manual available on-line? Any assistance is appreciated. Larry
  • Anonymous Jan 06, 2011
    Thanks for your response. I tried your recommendation with no positive result. Also, the manual reversing function (buttons) have no effect either. Any more advice?
    Yes, the deck plays. Just can't get the reversing functio to work--manual or auto. I'm the original owner of this system as I bought it in 1972 while with the military in Korea.
    Brigadier General:
  • 8,546 Answers
Just a guess. Have you cleaned the two conductors on the sensor? You can test its function by running the tape in either direction and shorting it with a non-ferrous metallic object, say, an aluminum. You don't want anything magnetic near your prerecorded tapes.
Posted on Jan 04, 2011
  • 1 more comment
  • David Dunn
    David Dunn Jan 06, 2011
    Your latest input regarding the failure to reverse under switch command is the FIRST thing we should have considered. Combined with the sensor issue we probably have a logic failure to drive the solenoid(s) that change transport functions. Does it even Play?
  • David Dunn
    So does it still Play Forward and Rewind / Fast Forward? I hate to say it but 38 years is a long time for a fossil to keep on keepin' on. I mean the machine, not you. I'm only a couple of years behind you and I had a Teac A6300 that would skew the tape off the capstan in reverse so I stopped using the Reverse function. That may be your only economical option unless someone with the specific expertise chimes in.
    Yes, it does all that. These machine are much better than those nerwer models. I also have a Sansui 8080DB Stero Receiver along with a Pioneer PL-530 Turntable which are fully functional that I purchased in 1977 while with NATO in Naples, IT. I've been searching for a business/firm that does overhaul/refurbishment of these type system with no avail.
    Thanks for your support!
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
Why does my deck not play in reverse?
check for a broken rubber band for the rewind spindle
bands available from Jaycar in packs
Nov 08, 2015 | Audio Players & Recorders
Where can I download a Service manual for AKAI DS4000 Mk-II
Hi Fi Engine is one place. The deck will have a disintegrated cam and might be a waste of time. MOST all Akai heads are worn out at this time and there are no replacements.
Aug 20, 2014 | Audio Players & Recorders
My Akai X-1810D reel to reel has basically no volume coming out of the speakers (when I put my ear next to the speaker it's barely audible) Manual says it could be Diode D3 (10DC-1) Where can I buy this...
You need to be sure of the correct failed part and I would not jump to conclusion without measuring a power supply failure or lack of audio after an amplifier stage- Akai was known for use of some bad transistors. I have had to deal with them myself. It is unusual for two channels to go out at once. It might be wise to treat all switches and pots with Deoxit spray which may resolve the issue without a part change..
Aug 21, 2013 | Audio Players & Recorders
Akai Manuals OWNERS MANUAL
The sensing tape must be fitted at the end of the reel just before the coloured leader tape
Apr 30, 2013 | Audio Players & Recorders
AKAI X-1810D LOW HUM WHEN RECORDING REELS
I am not an expert in the repair of Akai units- most of the time I refuse them, however just to put you on the right path, the hum is coming from a power supply issue in the record audio section or may be in the bias section. You may need to put new Electrolytic caps in the power supply to resolve this. You can also scope the supplies on this deck to find the cause. I commonly work on Teac, Pioneer, Otari, Studer, Sony and better made decks. Some brands are real trouble and are more costly to repair due to poor construction.
I have been doing repairs for 40 years so far.
Sep 05, 2012 | Audio Players & Recorders
How to check if Auto Reverse Works
Play a tape to the end. If it reverses, it is working properly.
Make sure that you have turned the auto-reverse feature on. The switch is next to the power button.
Jul 13, 2012 | Audio Players & Recorders
Although I placed both ends the necessary sensing foil ,when choose auto-reverse with my Akai GX-636 RtR only the right tension arm sense the foil and blocks without reversing.When in recording mode it...
I'm pretty sure the auto-reverse is NOT supposed to work during recording. What would be the point since it only records in one direction?
And I'm pretty sure there's only one reverse sensor, usually to the left of the heads and not necessarily on a tension arm. The sensor foil is supposed to be on the non-oxide side of the tape so it will adhere better and never contact the heads.
This picture of a GX-635 shows a typical transport ...
http://www.oaktreevintage.com/web_photos/Reference_Photos/Akai_GX-365D_Front_Face_Off.jpg
There's a knob for how the auto reverse. Is it set correctly? I believe infinite forward / backward play is possible if you have the knob set properly, a sensor foil on the tape and the tape counter set to 0000 at the beginning of the recording.
May 12, 2011 | Audio Players & Recorders
Just want to know whether there is a way to get a tape to auto reverse on the dual tape deck, and, what is the "OSD" button on the receiver for? This is an old Denon D-1250 shelf system. Thanks,
OSD = On Screen Display
Auto Reverse is a built-in feature of any tape deck. It would have a button that looks like > for forward and < for reverse; and probably a switch that sets the mode for automatic or manual reversal at end of tape.
Feb 24, 2010 | Audio Players & Recorders
160 people viewed this question
 Grubhead
Grubhead
