Question about GE GDS18LBP Bottom Freezer Refrigerator
Fridge defrosts but drain eventually freezes up and stops fan
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 04, 2011
Condensation in fridge
How long does it take for the condensation to build up and freeze the fan?
When was the last time you defrosted the fridge (unplug, open all doors for 12 + hours)?
If you have not defrosted the fridge recently, you may have blockage that is preventing a drain from allowing condensation to escape.
Mar 02, 2014 | GE Refrigerators
Dometic refrigerator Model # rm2610
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
Jul 23, 2010 | Dometic RM2652 Refrigerator
Kenmore refrigerator stop cooling but fan working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Apr 06, 2010 | Kenmore 53642 / 53644 Side by Side...
American stytle samsung f/freezer iceing up on fridge section
Sounds to me like a bad defrost control or a clogged drain line to remove the water after the defrost cycle has ended so the water just freezes again!
Aug 25, 2009 | Refrigerators
My freezer is still freezing but the fridge is not cold. You can hear it running but nothing. HELP!
is the fan running in the freezer? if not replace fan .if not unplug fridge,,remove all inside pannels in freezing unit,,in the bac ,in the middle, on the bottom ,there is a drain that drains into the very bottom of fridge,is it like aice bottom across the bottom of the freezer?if so,use hot water to defrost all the ice and may be a hair dryer,water will melt and **** down the drain threw the drain tube,to the bottom of fridge into a shallow pan under the fridge,that slides out(could be messey).clean all bottom of freezer out good(crumbs mostley)that stop up drain and pour water threw drain a few time to clear drain good.reasemble and ur good to go.now if there is no ice and drain is good,you might find ice on coils,this means ur defrost timer is most likeely gone out ,just replace timer
Jul 04, 2009 | Electrolux Refrigerators
Water drips from bottom of fridge. It happens
look in the bottom of the inside of the freezer, you probably will see ice buildup.You have to clear the drain which is stopped up at the bottom of the panel that covers the freezer evaporator.Every 8 hours the drain receives water from the auto defrost and needs to go in the drain, if drain is stopped up it freezes and eventually runs out the front
Mar 25, 2009 | Hotpoint HSS25GFP Side by Side...
GE Profile TCC18 Refridgerator freezes Up regularly.
I had the same problem. I changed the defrost thermostat and that has solved the problem. Just to make sure the problem is not recurring I drilled a small hole in the back of the plastic drain(behind the fridge) so that I can put a long screw driver inside to determine if there is any ice build up. None so far after 3 weeks.
Feb 28, 2009 | GE GBS22HCP Bottom Freezer Refrigerator
Fischer Paykel fridge freezes then stops
sounds more like a defrost problem, check your defrost timer, defrost heaters.
Feb 21, 2009 | Amana ABB1927DE Bottom Freezer...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Kenmore refrigerator freezer not freezing
Yes that is a proplem...when ever that compressor is running that fan motor should be running too.. also you evapurator fan motor should be running also
Aug 20, 2007 | Magic Chef CTB1722 Top Freezer...
GE GDS18LBP Bottom Freezer Refrigerator Logo
125 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
