Question about Whirlpool Calypso GVW9959K Top Load Washer
My Calypso washer beats up my clothes but doesn't clean them well. I have holes in my linens and all my towels have pulls in the terry.
I don't have the solution but I have the problem. I bought all new towels 2 years ago and they are all ruined.
Posted on Jan 04, 2011
  • Anonymous Jan 06, 2011
    I did that too . . . a couple times. I hate this washer.
Is there a fix for the washer it's chewing my towels
This washer is known to eat some clothes.
I found a great big silk pillow case between tubs once:
Most of the damage is done in the beginning of the cycle directly after the brain has re-destributed the clothes. Any items of clothing with strings need not be washed in this machine or the strings will get into the pump:
I wrote an article for FY on these:
http://www.fixya.com/support/r5224450-calypso_repair_manual
Nov 04, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
How to Open up a Kenmore Elite Calypso Wash Motion Washer: I opened up the lid but how do I release the the snaps that hold the inside machine to the outside...?? I have a lot of "sludge"...
Just checked the service manual on this model. To open top, first UNPLUG the cord, then gently pry off the emblem from the front trim. Behind it is a T-20 torx screw, remove it and then you can pull the entire top toward you, the front, about half an inch or so to clear the latch and lift the entire top. It's hinged at the back. Ensure you have enough room behind the machine for the console to clear and prop the lid up. If machine is still under warranty, I wouldn't recommend self service, if not, have at it, all you can do is save yourself some money!
Hope this helps
kcomp1863
Jan 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag Neptune/ clothes smell like mildew
Go out and buy a box of "AFFRESH". Run it according to the directions.
May 28, 2009 | Maytag Neptune Washer
Calypso Model 2408 ruining towels
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 20, 2009 | Kenmore Washing Machines
Where is the filter located on a kenmore elite calypso washer
reomovethe 3 screws across teh lower acess panel, youll see the filter clean out right behind there , be warned before unscrewing get a plastic bag, or a few towells you will getwet!!!!!!
Mar 17, 2009 | Kenmore Washing Machines
Whirlpool calypso
the calypso washer is much older then 2 years. they stopped making them quite a few years ago. what you are seeing is how towels will come apart when washed with an aggressive washer. even expensive towels can be poorly sewn and will come apart when washed too hard. i might suggest you use the light cycle as it has a slower washing cycle speed. if you check your older and "better" towels are not doing the same thing as your new towels. i know its not fair but it is the way towels are now. you can try to remove the threads that are coming off your newer towels and then all should be ok, but there is nothing wrong with your washer just the way towels are now.
Jan 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso
This could be an out of balance condition. When its happened to my washer, I rearrange the load if its large enough, and if its not, I find other items of like weight and add them to the load and start over. Calypso's are sensitive to fabric weight, so If you're washing towels, wash only towels and wash cloths. Make sure you put small items, like bras, panties, nighties, etc., in mesh bags and combine them with other light weight fabrics.
Aug 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso
Have you checked the agitator? There may be sharp edges on the agitator blades. OR the towels may be getting stuck under the agitator and tub bottom. The agitator is supposed to suck the clothing down in the center and forcibly throw the clothing outwards against the tub. The cycle then repeats.
Sep 09, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
