Question about LG LFC20760ST Stainless Steel Bottom Freezer French Door Refrigerator
Our LG LFC20760S refrigerator/freezer coldness setting is stuck. The refrigerator coldness setting is showing no values at all (and I can't update). The freezer coldness setting is stuck on 6 AND 7 (and I can't update). When I unplug and then replug in, the default coldness setting values (i.e. 4 for both) show. After a few minutes, however, the coldness settings return to the unusable state mentioned above.
  • LG Master
  • 8,220 Answers
That MIGHT be the control board but before you order anything you should check the thermistors. The board relies on data from them thermistors. If one is out of spec or even out of spec then that throws a monkey wrench in the works. What you need is a manual which shows the locations of these thermistors and some diagnostics info. French Door Service Manual
Posted on Jan 04, 2011
How to set freezer on LG Bottom Freezer LRFD22850
Hello Fran Miller,
For OPENERS... (my opinion)
always start by setting you temperatures at mid range.
Owners manual... Page 16
Setting the controls 16 - 17 Adjusting control settings...
http://www.searspartsdirect.com/partsdirect/user-manuals/LRFD22850ST-LG-Parts-Refrigerator-Parts-manual
I get a little PUSHY about FOOD TEMERATURES...
(stored poorly there's no quicker way of poisoning ones self)...
I strongly recommend getting TAYLOR refrig/freezer
THERMOMETERS (like Amazon... cheap = $6 ea).
Let the refrigerator stabilize EMPTY 24 HOURS
Loaded with food (not recommended: 72 hours).
ADJUSTING CONTROL SETTINGS
Give the refrigerator time to cool down completely before adding food. It is best to wait 24 hours before you put food into the refrigerator. The mid-settings indicated in the previous section should be correct for normal household refrigerator usage. The controls are set correctly when milk or juice is as cold as you like and when ice cream is firm.
THERMOMETERS
Amazon com Taylor Refrigerator Thermometer 20 Deg To 80 Deg 3 1 4 3 3 4...
Hope I am helping
Carnac the Magnificent
Jul 11, 2017 | LG Refrigerators
LG french door refrigerator with bottom freezer. Freezer is cold but the refrigerator is warm
Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...---/Refrigerator-freezer-is-cold-b...
Refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
LG Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...-/LG-Refrigerator-freezer-is-cold-...
LG refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
4 Reasons Why Your Freezer is Cold but Fridge is Warm ...
www.bestfridgereview.com/freezer-is-cold-but-fridge-is-warm
Jul 25, 2014 - Your freezer is cold but refrigerator is warm? This can be a very big problem. Check Out the top 4 most common problems and their solutions ...
Why is my refrigerator not cooling? - Refrigerator - iFixit
Jan 04, 2016 | LG LFC20770ST
Fridge too warm
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge( actually I think there are 2 fans in these, 1 horizontal 1 vertical) otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | GE Energy Star PDS22SIS Stainless Steel...
Srl629ev refrigerator
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge.Otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | Refrigerators
My refrigerator is not getting cold even though I have changed the temperature setting to the highest value. The freezer is working fine.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 11, 2010 | GE GSH25JFR Side by Side Refrigerator
The Fridge froze all inside and the generator works constantly. The settings are set to medium. Nothing changed after turning the power off and then back on after a few seconds. I'm assuming the thermostat...
Check the vent door from the freezer to the refrigerator...when you turn the refrigerator off with the knob, does the vent door close. The bottom of your refrigerator works from the freezer blowing cold air through the vent to the bottom of the refrigerator. If it is turned all the way down, that should shut off the flow to the bottom. If any thing is broke there, it will continue to let cold air come down the vent, so check it out. The vent knob itself might not be working to turn the vent door down or off. There also, is a relay on the back of the refrigerator that controls the compressor on and off...it could be stuck in on position.
Oct 28, 2009 | LG LRTP1231W Top Freezer Refrigerator
LG LDC22720SW ECU reads 5-6-7 on freezer side
I have a similiar problem with my LG refrigerator. The freezer settings get stuck on 6 and 7, while the refrigerator side is showing nothing. Pushing the buttons to adjust the temperature does nothing. The whole time, my food is getting spoiled.
Jun 28, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigertor isn't cold at all
Hello sewing6
Welcome,
You said,
digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigerator isn't cold at all
Try turning the fridge and the freezer off at the controls.
Then turning off the breaker for the fridge for 5 minutes .
then turn the breaker back on and restart the fridge and freezer!
This should reset the system and solve your problem.
let me know how it goes.
Thank You,
Huuum
Please remember to leave a rating! Hopefully a "solved "one.
Oct 12, 2008 | LG Refrigerators
LG LFC20760ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
151 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
