Squeeking/squealing all night long - Heating & Cooling
  • 2,133 Answers
Check blower motor alignment and seating bush. if blower motor bearing problem, the sound comes. Replace bearings. Check for blower- wheel broken or cracked, replace it.
Posted on Jan 04, 2011
How do I fix a squealing or squeaking fan in my portable AC
unplug unit and check play in motor shaft. if it moves perpendicular to the bearing the motor needs to be replaced. There may be something loose causing a squeeking sound. you could check all the screws for tightness.
Aug 22, 2014 | Haier Heating & Cooling
Squeeking and squealing 2012 harley trike
Hi Anonymous, call, take a ride or trailer your bike over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary/possible and offer professional advice and assistance concerning your issue. Good luck have a nice day.
Nov 04, 2012 | Harley Davidson Motorcycles
Squeeking idle
Tensioners should be replaced about every 80 thousand km when u let of the gas it relieves tension on belt tensioner if the spring inside is wearing out chances are there's ur squealing sound would sound like a belt squeal not a bearing
Feb 12, 2012 | Chevrolet C1500 Cars & Trucks
Why does my cobra 148 GTL CB give out a squeeking noise when i trasmit as heard by others receiving me ??
is this a new radio? if so then the voltage change on the vco/pll will cause a squeak. kindda like a cobra 19dx does. also like the old golden eagle squeal .. all due to the voltage being unstable.. now is it that prob or do you have talkback and its loud/bad grounds causing a squeal. that could be the case too. if you have talk back let me know there's a cure for that. contact us..we can put the talkback just lil outtaphase to stop 99% of the squeals in cobra/uniden chassis radios.
Dec 11, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Fax machine squeals when fax comes through
Usually the squeeking on most faxes/copiers that I come across is from a nylon roller on a steel shaft/bushing. You'll be able to tell by opening the back door and look at the little rollers. The plastic ones are usually the culprit and you'll need to carefully blow air through the holes in the center, or any mounting point/axel. VERY LIGHT oil can be placed on the shafts, but it will take a little while and a few copies/faxes to work its way in there.
Sep 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Squeeking noise at slow speeds
If its squealing from the wheels at low speeds with your foot OFF the brake pedal, check the brake pads. There is an EARLY WARNING SENSOR that's squeals like chalk on the blackboard when the brakes get low. Could be totally off on this one , but hope it helps.
May 06, 2009 | 2002 Buick Rendezvous
I have a 1994 suzuki sidekick that have this squeeking or squealing going on. It's making that noise even while I'm driving. I put a new alternator and power steering belt on it. Any suggestions. My engine...
It sounds like you Belt Tensioner is not Working Correctly. I would Replace the Tensioner. It should Fix the Squeeking Problem. Please Rate my Solution, I need all the Help that I can Get! Thanks!
Jan 29, 2009 | 1994 Suzuki Sidekick
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
