When machine is powered on displays error "Proctector" and "Push Power" Have already gone through troubleshooting steps included in owner's manual and contacted a tech support line. Neither fixed the problem.
  • 4,234 Answers
Without knowing the make and model, there is little detail we can provide. If you can update this with that information, I shouldbe able to assist further. In the meantime, please see the link below for an explanation of protect mode,
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Posted on Jan 03, 2011
Tip
How to Troubleshoot CF-19 The Panasonic Toughbook CF-19, commonly known as...
How to Troubleshoot CF-19<br /><span style="font-style: italic;">The Panasonic Toughbook CF-19, commonly known as simply the Toughbook 19, is a laptop computer geared towards people who work on location, such as field workers or military personnel, who require a sturdy and resilient device. Unique features of the model include its screen which can display clearly in bright sunlight, its touchscreen function and its backlit keyboard. If you experience errors or malfunctions with the CF-19, troubleshoot it to diagnose and solve the problem before replacing the device or seeking professional repair.</span><br style="font-style: italic;" /><br /><span>Instructions</span><br /><br /><span>Device Turning On</span><br /> <ol> <li> <span style="font-style: italic;">Check that the AC adapter is connected properly. One end should be plugged into the laptop and the other end should be plugged into a working AC outlet. If the adapter is disconnected at either end, connect it.</span></li> <li style="font-style: italic;"> Disconnect any device connected to the laptop's USB port or ExpressCard slot. A malfunctioning device may cause the laptop to malfunction and not turn on.</li> <li style="font-style: italic;"> Press the "Fn" and "F8" at the same time to turn off "Concealed Mode." This mode disables the power functions of the device.</li></ol><span>"Remove disks or other media. Press any key to restart" Error Message</span><br /> <ol> <li><span style="font-style: italic;"> Remove the floppy disk or CD-ROM from the device and press any key. This message indicates that the disk does not contain system startup information and cannot run on the device.</span></li> <li><span style="font-style: italic;">Disconnect any device connected to the laptop's USB port or ExpressCard slot as problems with these device's may also cause this message to appear.</span></li> <li><span style="font-style: italic;"> Contact Panasonic Technical Support if this problem persists after attempting Steps 1 and 2 as this may be a sign of a problem with the laptop's hard disk and it may need repairing or replacing.</span></li></ol><span> No Display/Screen is Blank</span><br /> <ol> <li style="font-style: italic;"> Press the "Fn" and "F3" keys simultaneously to switch to "Internal Display" mode as the device may have been set on "External Display."</li> <li style="font-style: italic;">Check if the device is in "Power-Saving" or "Sleep" mode by pressing any key on the keyboard. The screen should come on if the device was simply in "Power Saving" or "Sleep" mode.</li> <li><span style="font-style: italic;"> Turn on the display screen or monitor of the connected device if you have the laptop set on "External Display" and want the display to come up on that device.</span><br /></li></ol><span style="font-style: italic;"><span>Hopefully this can help<br /><br />regards<br />multilinkent</span></span><span><span><span style="text-decoration: underline;"><span style="font-style: italic;"><span style="font-weight: bold;"><br /></span></span></span></span></span>
on Jul 08, 2011 | Computers & Internet
"stuck key" message on efx 546i, will not engage, already replaced batttery
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Feb 17, 2013 | Precor EFX 546i Elliptical Version 4
The programs on my new smooth 9.65 LCi do not work
adjust the REED SWITCH, see the diagram , clean it, tight any plug or connector very well.
Tight the ribbon cable, and clean it with rubber pencil, for keypads display, and tight any connector or plug from display.
after that RUN the software calibration, for diagnostic,troubleshooting, and fix it.
God bless you
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step. The Calibration seq
Oct 14, 2012 | Exercise & Fitness
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
When I turned on my printer today all the lights on the front started flashing and this error message showed: "C4EB8000. Turn power off then on again." I've tried googling it and nothing seems...
Follow these steps to resolve the error message. It might not be necessary to complete each step to fix the issue. Step one: Disconnect all data cables and devices from the HP product
  1. Disconnect any USB, Ethernet, or parallel cables from the back of the HP product.
    CAUTION: Do not disconnect the power cord during this step. Figure 1: USB connectionc01661620.gif Figure 2: Parallel connectionc01369986.jpg
  2. Remove any memory cards or USB drives from the HP product.
Step two: Turn the HP product off and then on
  1. Press the Power button (c01602202.gif ) to turn off the HP product.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn on the HP product.
Step three: Reconnect the data cables and devices
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Reconnect one USB, Ethernet, or parallel cable to the back of the product.
  3. Press the Power button (c01602202.gif ) to turn on the product.
  4. Check the display for the error message.
    • If the error message does not display , reconnect another cable, and then repeat steps 2 through 4.
    • If the error message displays , replace the cable you just reconnected with a new one. Go to the How to Buy HP page to buy the replacement power supply for your product.
Step four: Determine if the HP product uses a power cable or a power module as the power supply If the power supply is a cable with electrical connections at each end, the product uses a power cable . Figure 3: Power cablec01369983.jpg If the power supply is a cable connected to a module or box, the product uses a power module . The power module might have a permanently attached power cord, or the power cord might detach from the power module. The term power module refers to both the power module and the power cord. Figure 4: Power modulec01369984.gif c02020663.gifIMPORTANT If the product uses a power module, make sure that the power module part number is the same as the part number listed in the User Guide to ensure you have the correct power module. If the part numbers do not match, replace the power module. Go to the How to Buy HP page to purchase the replacement power module for your product. Step five: Check the electrical connections and outlet
  1. Disconnect the power cable or power module from the back of the product.
  2. Disconnect the power cable or power module from any power strips or surge protectors.
    NOTE: If the product uses a power module with a detachable power cord, unplug the cord from the power module, and then plug it into the power module again.
  3. Wait 30 seconds
  4. Plug the power cable or power module directly into a wall outlet.
  5. Reconnect the power cable or power module to the back of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
  7. Monitor the product to see if it turns on then off again.
    • If the product remains on , you might have too many devices plugged into the power strip or surge protector. You might also need a new one.
    • If the product turns off , the source of the problem is the electrical outlet. Continue to the next step.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Nov 11, 2010 | HP Photosmart C5280 Printer
"Protect" and "Push Power"
i have a sony component push power protect, i have already replace IC but still protect push power
May 02, 2009 | Sony Audio Players & Recorders
Ge Adora washing machine counts down, but won't wash.
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 28, 2009 | Washing Machines
Error 1203 Lexmark F4270
The 1203 error message is caused by a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. The procedures in this article will help you to resolve this issue.
Troubleshooting a Communication Error between the Cartridge and the Printer
Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, and then repeat steps 4 and 5 of this procedure. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7 Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2 Remove the cartridges. Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
click here for instructions).
Dec 16, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error e5 showing
Step 1 : Push Power switch by continue (Tekan Power On/Off)
Step 2 : inserrt plug(Masukan Power, Power Tetap di Tekan)
step 3 : Tekan Tombol Reset 1x, lepaskan Tombol Pwr, Tekan Reset dua kali lagi Sampai Menjadi 0 (tekan tombol tanpa jeda)
Step 4 : Push + display change from 0 to 1 (tekan tombol + untuk merubah 0 ke 1)
Step 5 : Push Power switch again , Printer will be print 1 page(tekan tombol power –> tombol start sampai ngeprint 1 hal.)
step 6 : Open cover (buka tutup printer)
Step 7 : Unplug (cabut kabel power)
Step 8 : Take out ink 40 and 41(lepaskan catridge 40 dan 41)
Step 9 : Insert plug again (pasang kabel power)
Step 10 : Push power switch (tekan tombol power)
Step 11 : Open cover (scan cover) (buka tutup scaner)
Step 12 : Inksert ink 40 , 41 again (masukan catridge 40 dan 41)
Dec 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
35 people viewed this question
 Grubhead
Grubhead
