Question about Carrier Heating & Cooling
RTU 12 ton - Blower Motor Contact is rapidly clicking in and out.. & low volt transformer to hot
  • Carrier Master
  • 43,501 Answers
There is on of two things happening...either the contactor is going bad (coil) and it is pulling too much current causing the transformer voltage to drop... or the transformer is going bad causing the contactor not to hold in because of low voltage...
Pull the wire from the contactor and check the transformer voltage...if it is a 24v transformer then the static voltage should be like 26-27 vac...then ohm out the coil and check that it is not shorted...
Also check incoming voltage to make that is not low... it could compound and cause a low transformer voltage...
Sometimes the easiest way to find the exact cuase is to either change the contactor... (I often just plug a new one in and see what happens before installing it) or the transformer... so you can see which one is the problem...
heatman101
Posted on Jan 03, 2011
No heat, no fan. Fuse is fine.
check see if power going to blower motor using 12 volt tesl light.if yes, remove blower motor, hot wire it.if blower motor works problem in the control switch or short in blower motor wiring,if blower motor dont work when hot wired,blower motor is bad.
Feb 07, 2012 | 1991 Volvo 240
2004 1 ton dual wheel work van Blower motor not working .changed resister.. still nothing checkrd fuses. have 12 volts on red and black wires at resistor.. no other wires at resistor have power even...
The switch doesnt "power the resistor" it GROUNDS it. I dont have a diagram here at home, but how about the wires at the blower motor.If both are hot, theres a bad ground somewhere. Did it act up before it didnt work? So is it a VAN or a truck? 04 or 01?
Sep 01, 2011 | 2001 Chevrolet Silverado 2500HD
12RES GEN.NAT.GAS FAILS TO START BY STRT BTTN AND TRNSFR SW
If the succession is 3-5 sec crank - 3-10 sec pause, it is OK, but the cranking is not successful (the reason should be investigated).
If the succession is more rapid 1 - 2 sec you may have bad PCB control.
Jun 03, 2010 | Kohler 12 kW Emergency Power System -...
2004 trailbrazer heater blower only works on high setting
Your blower resister is bad. Remove it and check to see if it any burned spots. If you resister is bad either A, your pulling to many amps, or B your blower motor is bad also.
You should be able to check your blower motor by hooking red, 12 volt hot tp connector, and black to frame ground.
Feb 01, 2010 | 2004 Chevrolet TrailBlazer
1997 Chevy s-10 pickup (2.2L) Blower Motor problem
I don't know what you mean by temp module but i'am gessing the switch on the dash, but to me it sounds like the resister is bad, i believe its located under the hood on the air box if not than chk. under the dash by the heater motor, i have seen the wires burn that plug into it when they go bad, thats what makes the blower run and also regulates the speeds of the blower motor.
Oct 11, 2009 | 1997 Chevrolet Blazer
2002 Tahoe Rear A/C doesn't work
check fuses & power to blower fan motor,plug connections.then apply 12 volts to blower fan motor if it dont turn its bad
May 08, 2009 | 2002 Chevrolet Tahoe
Blower motor does not work at any speed
as you said relay is good,try to check 4 connection of relay,pullout relay,check if there a 12 volts supply,, a 12 volt control by ignition sw.,connection to blower motor, the last connection is to the switch mostly connected to ground.
Feb 15, 2009 | 1999 Dodge Ram 2500 4WD
1999 cadillac deville blower dont operate. What should the voltage be at the red wire and the gray wire or the black wire ? Iam assuming the red wire should be 12 volts, the gray wire should be variable...
red black and gray are just half the connections. Red is positive 12 volts coming from fuse of circuit breaker. The black wire is either the ground or the main hot wire going to the blower motor (3 pin connection only), and the gray wire (if is is small in size) is a variable voltage coming from the body control module requesting speed for the blower motor.The blower control module varies voltage on the main wire going to the blower motor, supposedly in accordance with the requested voltage from the body control module. Usually if all fuses are okay and present on the apprpriate wire of the blower control module, the a blower motor that will not run or stays running after the key is turned off is the fault of the blower control module. If the blower control module has failed the the cause must be determined (over amping blower motor) or else new blower control module may fail when powered up.Usually blower control modules have more than three wires. Usual connections are: B+ (battery voltage) GND (chassis or engine ground), two large wires going directly to blower motor (can be any color, but are usually 10 guage in size), and an optional wire that reports voltage level back to the body control module.
Jan 11, 2009 | 1999 Cadillac DeVille
Heating & Cooling Logo
46 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
