Question about Welding Tools
Wire feed will not syay engaged will start and loose contact after afew seconds aprox 20yrs old 3 phase kempi 250 amps hand peice contact on trigger ok
  • 7 Answers
SOURCE: wire feed motor wont run
Do the wire drive wheels turn?
if not then trouble shoot wire feed system for defect.
Posted on Mar 21, 2009
SOURCE: NO WIRE FEED BUT WELDER CLICKING AS IF FEEDING
This could be caused by not enough pressure on the drive wheel. Try adjusting pressure as spelled out in you manual.
Posted on Apr 10, 2009
  • 850 Answers
SOURCE: Snap-on YA219 mig feeds wire & gas when
check the aerth [ground cable & connections]
Posted on Jul 20, 2009
  • 92 Answers
SOURCE: No arc/ no burn
You need to inspect the ground.Where it connects to the machine, and at the end. I bet one of the connections or the wire itself is damaged.
Posted on Jul 21, 2009
  • 6 Answers
SOURCE: Wire feed does not stop. Not the trigger.
you have a problen with the electronic circuit.
Where are you?. Perhaps I can help you.
Posted on Aug 16, 2010
I have a 250 bobcat that stick welds just fine but when you go to wire feed and plug in suitcase box wire feed unit wire feeds but it doesn't get hot enough to melt the wire. LF299725
What model of suitcase? Could be the contactor in the suitcase, could be the mig gun. Are you using the CV setting on the Bobcat, instead of CC? Is the Bobcat on the high CV setting and the dial most of the way?
Apr 30, 2012 | Miller Bobcat 3 Phase Welder Generator...
MIG welder 250 feeding wire at erratic speeds
Gun trigger contacts or switch circuit is closing somewhere (shorting). Unplug connector and jump the two terminals if it works and will weld disconnect jumper if problem persists it is not in the gun or cable hose. Keep chasing it far as possible without taking bolts or screws out of machine unless you know what that stuff inside will do to you, pretty sure the problem is not in there anyway.
Apr 02, 2012 | Miller Welding Tools
My welder feeds normal for the first 10 to 20 secs then struggles to feed wire. I have replaced feed tube and wire, adjusted tension both ways andput new tips, currently using .035 for.030 wire. I think it...
Depending on how old you machine is, its possible that the wire feed rollers are worn causing the wire to slip in the grooves. Replacing the WFRs may solve the problem. Test this by watching the feed rollers as you pull the torch trigger, place a gloved hand over the nozzle as the wire comes out and watch to see if the rollers slip on the wire when the wire meets the resistance of the glove. If it does that likely the problem. Hope this solves the problem.
Jun 19, 2011 | Hobart Handler 125 115 Volt 30 To 125 Amp...
My hobart handeler 125 will not stop feeding after i release the trigger, why?
The trigger is bad in the gun. It sound like the spring is bad, or you have some junk in the trigger not alowing it to release. Remove and inspect/clean the trigger.
Nov 04, 2010 | Hobart Handler 125 115 Volt 30 To 125 Amp...
My zero turn lawn mower will not engage the blade. It temporarily came on and shut off. I have checked the electrical hook ups. The last time I mowed it came on about 20 seconds after I pulled the knob and...
Buy some electrical contact cleaner and spray in any orifice you can find in the pto switch an then blow out with compressed air. If this does not work locate your pto safety switch and do the same to it. If either works would have a spare on hand just in case.
Aug 31, 2017 | Cub Cadet Riding Lawn Garden Zero Turn...
Bakers pride electric deck ovens aprox 10 yrs old
It depends on the ampere rating, you will not normally be able to get a single phase supply in the UK at more than 100 amps total.
If the total oven rating is not more than 60 amps you may be ok.
Conversion would involve altering the wiring in the oven which may be costly and not worthwhile on a 10 year old oven.
Jan 06, 2010 | Bakers Pride CO11-G2 Gas Double Oven
Just bought wells fyer model # F-67
3 phase is VERY DANGEROUS, contact an electrician,
Jan 26, 2009 | Wells F-67 21167 Deep Fryer
CP 302 wlder
Trigger the wirefeeder while listening for the contactor on the CP302 to close, if it does start looking for loose, bad or missing ground connections to the work, then look for the power connection from the CP302 to the wirefeeder to be bad. If the CP302 contactor doesn't close look at the control cable between the wirefeeder and the CP302, try a different one if possible. If you hear the contactor close, and everything else is good, check the voltage at the CP302 output terminals to see if you may have a bad contactor.
Oct 29, 2008 | Miller Electric Mfg Co 903376 Deltaweld...
I have a carrier heatpump unit. 20yrs old. the contacts need to be changed. i can't get the first spring loaded contact out. what's the trick without tear it up? this is for the a/c side.
This is a one peice deal, the contact switch on the outside condensor that has two smaller wires and biger wires coming to it all replace together. Remember your wiring and get a whole new double pole contact switch.
Jul 06, 2008 | Heating & Cooling
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
