Question about Dirt Devil M084000 RoomMate Upright Vacuum
Where can I buy a microfresh fliter Part #1-400321-000
Dc15 filter stuck
Doesn't the filter comes out when you release the lock?
Apr 02, 2008 | Dyson DC15 All Floors - The Ball Bagless...
I need to fix a problem with my Royal MO88520 canister vac. It makes a popping sound as i push it related to the pop-up wheels. Also have ordered filters for it twice and keep getting wrong ones.
Hello John Slife,
I searched the internet high & low (UK &USA) ...
I even found your question to them about a week ago...
I could not see your answer... but I can tell you I found nothing.
By this time I would usually have a good idea of the color, style & options... All (I think ... is it was a 2002 model year)...
Unsure results:
ereplacementparts.com your number resolved to a DIRT-DEVIL BAGLESS UPRIGHT... But the two items YOU ARE INTERESTED... their Micro-Fresh perma (cylindrical) filter...
and the wheel set... both show as discontinued...
2860211000 Microfresh Perma Filter Assembly
My advice would be to go to their site and speak to their help... or a local vacuum shop. A good repair person can often find viable ALTERNATIVE parts based on your actual needs.
FIND PARTS FAST
Sorry... not much help
SEARS brags a lot... I remain unimpressed but you COULD give them a try
Water Filters Lawn Garden Appliance Parts
Aug 07, 2016 | Royal Vacuums
I have a Bissell powerfoforce Bagless. A friend just gave me her older one, she is off to buy a newer model. I have been through every vacuum cleaner you can image, dirtdevil , kirby, etc and on and on. Sh...
There are at least 18 different models of Powerforce. There are too many parts and pieces to be able to describe what you need without seeing it. I suggest paying your local vacuum shop to put it back together. It may need a new belt, brushroll and/or filters. Do scrimp on these things if you want it to work properly.
Mar 14, 2017 | Bissell 6594 PowerForce Bagless Upright...
How do I clean the filter? can it or any part of
The fliter can be tapped aginst a garbage can to release soil. Using compressed air outside to blow off remaining soil and dust. The manufacturer will have replacement filters available.
Oct 10, 2009 | Black & Decker 15.6 Volt DustBuster Vacuum
Where is the filter?
If your machine looks like the one pictured it only has a bag.
Jun 26, 2009 | Eureka Bravo II Bagged Upright Vacuum
Cleaning the filter on the Dyson DC17
The fliter is under the canister. Take it off as if going to empty the dirt out. There is a cap that lifts up to clean the filter. I washed mine and let it dry (it took almost 3 days) before replacing it.
Apr 24, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
IRobot 5800 Scooba Vacuum dirt not going into the fliter basket
You can try rinsing the tank very thoroughly with warm water. Be very sure that you rinse the four ports on the underside of the tank (one round, two oval, one curved like Scooba's filter) very thoroughly, because all the dirt and dirty water moves through those openings and can clog things up.
Fembot
Jan 02, 2009 | iRobot 5800 Scooba Vacuum
Upright Vacuum Cleaner Lost Suction
If you had the dryer sheet under the intake filter for any length of time you risk burning out the motor . If
it smells like burning hair and plastic then the motor is toast. Also check the hose and dust passage, but I fear that it is the motor.
Sorry...
Sep 24, 2008 | Kenmore 31913 Progressive Direct Drive...
Electrolux Oxygen Remote Control Z5654 Vacuum Cleaner
Check your hose for obstruction. That might be the problem. If not, you will probably need service.
Jan 02, 2008 | Electrolux Z5935 Bagged Canister Vacuum
Dirt Devil M084000 RoomMate Upright Vacuum Logo
75 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
