Question about Compaq Presario C552US Notebook PC
Trying to replace the fan get all the screws out and it feels like it is still stuck to the fan area any advice?
    Scholar:
  • 77 Answers
It might fixup with the heat sink with the help of lock.
You need to find that lock to unlock.
thanks,
Satheesh
Posted on Jan 04, 2011
Waterford propane heating stove fan noise
Hi
Just check out for any loose screws or bolts. Maybe the fitting has gone loose, before that check out if anything is stuck in the fan area. Use a blower to clean the area. hope it solves the issue. Dont forget to leave a comment.
Regards,
Javeed
Apr 13, 2014 | Heating & Cooling
Dose anyone have a owners manual for a true refidgerator GDM-12
The fan your referring to is the condensor fan. it should not be tight to turn. it should spin freely. if it is hard to turn, its probably stuck, which is why its not spinning. Remove grill, slide the nottom portiom out so you have access to fan, remove fan blade, and spraylubricant on fan motor (around the area that the screw that held blade). Remove hair, dirt, string, or anything else that might be prevrnting fan from spinning. sometimes its easier to burn it off. If fan still doesnt spin you may have to replace fan motor.r
Sep 26, 2012 | True GDM-12 Refrigerator Commercial
Where is fan 1
If you have a fan error i would replace them all.
You can get get parts for this tv at www.interliquidparts.com
Nov 26, 2011 | Samsung LN40A650A LCD TV
My env3 wont stop vibrating
******** problem
Hi, what makes nothing happens even when trying different levels of the vibration is because the ******** of the phone that makes the phone vibrate when someone calls is damaged.
You need to replace the ******** before it will respond again. It is located inside the phone,always round in nature.
When replacing the ******** of the phone,you have to be careful when unscrewing the phone screws.
Get a phone screw, unscrew necessary screw off, take the back cover off locate the ********, (round like the ringer)But the difference is clear.Go to any phone repair store around your area and purchase another phone by tell them the model and make of the phone.
After replacing the ********, screw back the screws and your done.
Would advice, if no knowledge about phone repairs, please contact a skillfull personnel for help.
Thanks for using fixya..
Jan 17, 2011 | LG enV3 VX9200 Cell Phone
How can you tell if it is working or not, it used to have a visible mist coming out, now it doesn't, you can feel air coming out and hear the fan working, but is it working?
Check the fan area on the base. My spongebob humidifier did the same thing, and then I noticed smoke and sparks coming from the fan area. i am trying to contact Crane for a replacement, but its 2 years old, and warranty is over.
Oct 25, 2010 | Crane Cow Humidifier
Buzzing from lower area - replaced relay and cap - not freezing - staying cold but not freezing - Synptom: Click -humming for 15 sec-click cycles like that every 5 minutes Compressor is warm to Hot - fan...
If the defrost cycle was stuck on then the compressor would not be humming trying to start. You may have a shorted compressor. Especially if its a frigidaire they are known to have the worst compressors. You can use a meter to check your compressor windings. You can check for a short by scratching the paint off the compressor and checking from each terminal to the bare metal on the compressor. If you have continuity then its shorted. Also check continuity from each pair of pins on the compressor. Good Luck _MJ_
Mar 14, 2010 | Jenn-Air JCB2282H Side by Side...
Any info on electrolux RA1300 gas fridge. Freezer works well but fridge compartment doesn't chill
If you had an electric fridge the problem is usually the evaporator fan motor ($30).
I suspect that you may have the same problem. Generally, freezers are cooled only, when the fridge needs cooling, the evaporator fan comes on and blows cold air from the freezer to the fridge compartment. The advice below is for an electric fridge but may also work for you, it's worth a try I suppose.
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Available from a parts supplier or electric motor company.
Unplug fridge, or disconnect gas etc. Fan should be located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Nov 10, 2009 | Electronics - Others
Freezer freezes but refrigator not cold
your fan between the freezer and fridge is out. This fan allows the cooling from the freezer to cool your fridge section. This fan is located between the freezer and the fridge in the area of the temp control knob in the fridge. This area should be able to be accessed by pulling the screws that holds the assembly to the top inner part of the fridge. Once this part is removed you can see the fan. Take the model and serial number to the appliance parts store for correct replacement part. Understand that this is a 7 in difficulty on a scale of 1 to 10 to replace so if you feel like it you can repair it yourself however a tech could do it must faster at least you know what is wrong. Good Luck hope this helps on your repair
Dave
Sep 02, 2009 | Refrigerators
Canon Rebel XTI Ef-S Lens stuck
Hello Pittsburgh! I lived there for 3 years! Dreadful city. :-)
Now, your lens must have a problem with the guide rails/pins. If you dropped it or bumped it, you might have broken/damaged those guide rails. Another reason might be sand/grit in the zoom mechanism.
You may try stripping the lens slowly and see if you can identify the problem. Most lenses are easy to disassemble, you start from the rear mount area, take off screws, and parts one by one, and be organized (i.e., take photos for every step and don't mix the screws).
Good luck.
K.
Aug 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Cleaning
Model E20739: The entire back comes off to expose the fan blades after removing two screws. Just unplug the unit. On the back of the unit near the top is a recess that acts as a carrying handle. In that area you will see two large silver-colored screws. Remove these, grasp the back of the unit and push down on it as you pull it away from the body of the fan. You may have to wiggle it around a little to free it.
Jun 22, 2008 | Lasko 48" Xtra Air Tower Fan with Air...
Compaq Presario C552US Notebook PC Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
