Question about Dryers
Need to know where the belt is.It is extremely loud.
  • Dryers Master
  • 7,482 Answers
The problem with the noise is probably the drum rollers have flat spots on them or is in need of lubrication.
With the instructions I gave you below you can repair the drum rollers while you check the rest of the dryer.
I also included a link where you can see your belt routing if needed.
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Posted on Jan 04, 2011
I need to know all the kinds of belts that are in a 2003 ford escape and where they are located
Depends on the engine that is in that car but there are usually at least 2. One is very long and it called the serpentine belt. The other usually runs power steering or air conditioning.
Dec 30, 2013 | Cars & Trucks
1998 Ford F150 5.4 liter V8 squealing problem. Ok, I have this loud squeal that sounds like a pulley or belt. It is getting worse by the week. At first, I would spray some WD40 on the pulleys and it would...
I don't think its the CPS, but I do know that WD40 will make a squealing belt even worse. If you havnt replaced the belt yet, I would do that.
Let us know if that helps.
Jan 22, 2013 | 1998 Ford F150 Regular Cab
Bissell powerforce bagless extremely loud.
It could be that the belt is worn. You can get replacement belts and the manual here:
Bissell PowerFrorce Belts and Manual
Nov 21, 2009 | Bissell 6594 PowerForce Bagless Upright...
Extremely loud and smells like rubber burning
the loud will be the line is clog up and need to unclog the line, rubber burning will be the belt, which is worn or the brush is jam not allowing the brush to spin freely. check and clean the line and inspect th belt which run from the motor to the brush
Nov 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hotpoint dlb1550 squeeks extremely loud. Otherwise works fine
the squeaking that you hear is probably the belt slipping. it needs to be replaced. they are easy to find on the internet, just search by your model number of dryer and search for parts. if you need directions on how to change it, let me know
Oct 28, 2008 | Hotpoint TDL15 Electric Dryer
When attachment hose is on, it's extremely loud
That only happens to me if I leave the vacuum on the carpet and don't raise the head before 30 seconds...it is the rubber belt hanging on the metal thing that it sits on. Since the belt is not used with the hose attachment, I cannot imagine what is going on. Therefore, I've been no help at all! Just to let you know it happens to others - just slightly differently.
Aug 08, 2007 | Kirby G4 Bagged Upright Vacuum
Eureka 5849A Boss bagless upright
remove belt to brush roll and see if noise persists. if it stops, you probably need a brush roll. at least doing this will narrow down the fault area
Mar 26, 2007 | Eureka 5849A Boss Bagless Upright Cyclonic...
Dryers Logo
Top Dryers Experts
