Ok, so the first poster obviously didnt read the question and just posted the first thing he googled.
So I'll try. You have a short, most likely on the actual drive motor itself or in the switch. I wouldn't bother with replacing the fuse again until you take the motor out or test the switch for a short.
Sunroof Description and Operation (One Connector System)
Sunroof
This diagnostic procedure is to be used for the 1 connector Sunroof System that combines the sunroof control module with the sunroof motor/actuator.
The Sunroof System consists of the following components:
• BATT MAIN 2 Fuse 50 A
• Body control module (BCM)
• RAP relay
• S/Roof Fuse 20 A
• Sunroof module (includes sunroof motor/actuator)
• Sunroof switch
The Sunroof System is controlled by the sunroof switch and the sunroof motor/actuator assembly.
When the ignition is turned to RUN or ACCESSORY, or when the retained accessory power (RAP) system is active, the body control module (BCM) applies a ground to the RAP relay in the instrument panel (I/P) fuse block. This activates the RAP relay and allows battery positive voltage to be applied through the SUNROOF Fuse to the sunroof module. Ground for the sunroof module is supplied from G302.
The sunroof can be placed in 3 preset positions:
• Open
• Vent
• Closed
When the sunroof switch is placed in the OPEN position, a ground is applied from the sunroof switch low reference circuit , through the sunroof switch and to the sunroof switch open signal circuit. The sunroof motor/actuator then applies voltage to the sunroof motor open control circuit and applies a ground to the sunroof motor close circuit. The sunroof motor then opens the sunroof to the full open position.
When the sunroof switch is placed in the VENT position, a ground is applied from the sunroof switch low reference circuit , through the sunroof switch and to the sunroof switch open signal circuit. The sunroof module then applies voltage to the sunroof motor open control circuit and applies a ground to the sunroof motor close circuit. The sunroof motor then opens the sunroof to the VENT position.
When the sunroof switch is placed and held in the CLOSED position, a ground is applied from the sunroof switch low reference circuit , through the sunroof switch and to the sunroof switch close signal circuit. The sunroof module then applies voltage to the sunroof motor close control circuit and applies a ground to the sunroof motor open circuit. The sunroof motor then closes the sunroof.
The sunroof can be placed in any preferred open position when:
• The sunroof is in the fully opened position by pressing and holding the sunroof switch in the CLOSE position until the panel has reached the desired position then release the CLOSE switch in order to stop the sunroof
• The sunroof is opening, it can be stopped by momentarily pressing either side of the switch.
The sunroof control module, sun roof actuator, and the sunroof motor are integral parts of the sunroof module assembly and are not service separately.
Your best bet , take it to a qualified repair shop or buick dealer .
You mean GMC not Chevy ! Chevy doesn't make the Envoy . There is no way to manually close the sunroof !
Power Sunroof Inoperative
If voltage is not measured on the sunroof switch open signal or sunroof switch close signal circuits, the fault could be in the retained accessory power (RAP) supply voltage circuit, battery positive voltage circuit, or sunroof motor ground circuit. If the sunroof motor is not being powered, neither will the sunroof switch signal circuits.
Attempt to operate the sunroof through its full range of functions in order to verify that the power sunroof inoperative fault is present.
Does the power sunroof system operate normally?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
YES - Go to Step 3
Is the sunroof in the fully closed position?
YES - Go to Step 4
NO - Go to Step 7
Measure the voltage from the sunroof switch open signal circuit of the sunroof switch harness connector to the low reference circuit of the sunroof switch harness connector.
Does the voltage measure near the specified value?
B+
YES - Go to Step 13
NO - Go to Step 6
6
Measure the voltage from the sunroof switch open signal circuit of the sunroof switch harness connector to a good ground.
B+
YES - Go to Step 14
NO - Go to Step 10
7
Measure the voltage from the sunroof switch close signal circuit of the sunroof switch harness connector to the low reference circuit of the sunroof switch harness connector.
B+
YES - Go to Step 15
NO - Go to Step 9
9
Measure the voltage from the sunroof switch close signal circuit of the sunroof switch harness connector to a good ground.
B+
Go to Step 14
Go to Step 10
10
Disconnect the sunroof motor harness connector.
Measure the voltage from the battery positive voltage circuit of the sunroof motor harness connector to a good ground.
B+
Go to Step 11
Go to Step 19
11
Measure the voltage from the retained accessory power (RAP) supply voltage circuit of the sunroof motor harness connector to a good ground.
B+
Go to Step 12
Go to Symptoms - Computer/Integrating Systems in Computer/Integrating Systems
12
Turn OFF the ignition.
Measure the resistance from the ground circuit of the sunroof motor harness connector to a good ground.
Does the resistance measure less than or equal to the specified value?
5 ohms
Go to Step 16
Go to Step 20
13
Test the sunroof switch close signal circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 23
Go to Step 18
14
Test the sunroof switch low reference circuit for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 23
Go to Step 18
15
Test the sunroof switch open signal circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 23
Go to Step 18
16
Test the appropriate sunroof switch signal circuit for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 23
Go to Step 18
17
Inspect for poor connections at the harness connector of the sunroof switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 23
Go to Step 21
18
Inspect for poor connections at the harness connectors of the sunroof motor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 23
Go to Step 22
19
Repair the short to ground or open in the sunroof motor battery positive voltage circuit. Refer to Wiring Repairs and Connector Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 23
20
Repair the open in the sunroof motor ground circuit. Refer to Wiring Repairs and Connector Repairs in Wiring Systems.
Go to Step 23
21
Replace the sunroof switch. Refer to Sunroof Switch Replacement .
Did you complete the replacement?
Go to Step 23
22
Replace the sunroof motor. Refer to Control Module References in Computer/Integrating Systems.
Go to Step 23
23
Operate the system in order to verify the repair.
System OK
Go to Step 2
Some sunroofs have a open switch like the drivers window. You push it and the window will open automaticly. The button on your sunroof could be jammed so even though you can close it as soon as you release it, it will auto open on it's own.
Hey Paul, there are limit switches integrated into the motor on your sunroof, usually if it stops completely its because it detected a restriction, such as leaves, or dirt, if there are no visual sign then with the key on hold the switch to the full open position for 10-12 sec then hold it in the close position for the same, cycle the key and see if it reset. The motor can fail as well but it's not very common.. Do u hear any clicking from the motor area when this occurs, also check all fuses to be safe as well,..
It can be faulty motor or loose wiring issue or faulty /weak sunroof controlling switch or there is some blockage for sunroof to come down to close or sunroof out of its track the headliner is out of its way.There re many possibilities.All this basics needs to be checked.For further troubleshooting,go through this help link:---- Click the link mentioned below:------ How to Manually Close the
Sunroof ?http://howtobyme.blogspot.in/2012/05/how-to-manually-close-sunroof-on-2001.html
The fuse and relay box on the E30 and E36 models is located in the engine compartment. The E36 models also has relay boxes located under the left side of the dashboard. Circuit Breakers Resetting & Replacement Circuit breakers are located inside the fuse panel. They are automatically reset when the problem corrects itself, is repaired, or the circuit cools down to allow operation again.
One of the less known about fuses that can cause all this to go out is the fuseable link. It is in a black plastic box near the battery. It is an appx 60A thin metal strip fuse. Check the website link to the right for more info.
Also, I suggest check your Fuse Diagram in the BMW 525i Owners Manual here. Power Sunroof Emergency Closure Operation The sunroof is equipped with an emergency closure feature should the sunroof motor fail or the vehicle has lost electrical power. To close the sunroof under these conditions:
Remove the front headliner trim panel.
Using the 6mm hex key that is included with the tool kit, insert the key into the hex socket and turn the socket to close the sunroof.
Fig. Remove the trim panel to access the sunroof motor
Fig. Insert the 6mm hex tool from the tool kit and turn the hex socket to close the sunroof
Removal & Installation E30 Models
Fig. Sunroof components-E30 3 Series shown, E36 similar
Fig. Sunroof lid retainer clip location-E30 3 Series shown, E36 similar
Open the sunroof lid 2-4 inches (5-10cm).
Unclip the roof liner frame and push back into the opening.
Close the sunroof lid and loosen the screws on each end of the gates.
Pull in the retainers, remove the center screws and lift off the lid.
Remove the cover over the motor and gearbox. Close the sunroof lid, if not already closed.
Disconnect the wiring harness and remove the 3 mounting screws. Remove the motor and gearbox.
Push the cables back evenly on both sides. Remove the rail covers and pull the cables out of the guides.
Place the cable in the center position of the gate and press off.
To install:
Install the cables to the gate. The cable are marked with the proper side of installation. Do not lubricate fabric covered cables.
Pull the cables through guides and align the cables. Insert a hex key through the gate and cable at the 0 position.
Install the motor and gearbox. The motor and gearbox must be synchronized with the hole in the drivegear aligned between the centers of the 2 gears. Torque the bolts to 2.0 ft. lbs. (2.8 Nm).
Install the sunroof lid. Use new screws and torque to 2.5 ft. lbs. (3.5 Nm).
Adjust the sunroof lid. Pull the roof liner frame into position and clip into place.
E36 Models
Close the sunroof fully. With a quick actuation of the sunroof opening button, open the sunroof so the back edge of the lid depresses 0.08-0.12 inches (2-3mm).
Slowly push the roof liner panel back into the roof. Do not force or use a quick motion or damage could occur.
Remove the mounting screws and pull the lid off at the rear side. Do not operate the sunroof with the panel removed.
To install:
Install the lid and check that the hooks and levers align. Install the screws with threadlocker or use new micro-encapsulated screws. Torque to 2.5 ft. lbs. (3.5 Nm).
Adjust the sunroof lid. Lower the rear of the lid by operating the motor. Pull the liner forward and clip into place.
