Question about Henry Numatic "" Canister Vacuum
Kenmore vacuum 116.36720600
My vacuum just cut off. i can't get it to come back on. HELP PLEASE???? the henry just stopped ,ive had it in bits can,t see anything amiss
wondering why every wire seems to be live including neutral ???
  • love2mendit Jul 11, 2008
    Its fixed there was a break in the neutral wire in the cord !!!!!
  • Anonymous Aug 08, 2008
    is the same problem
VacuumRepair
  • 438 Answers
SOURCE: Belt broken a a Kenmore
Greetings from GoVacuum.com,
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled.
Feel free to email me if you have any further questions, I'd be happy to walk you through it, or even shoot an instructional video to show you how you to replace it. My email is chris.jones at govacuum . com.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Posted on Oct 01, 2008
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
SOURCE: repair kenmore elegance vacuum model 116
My Kenmore Elegance 116 turns on the powerhead but the vaccuum motor does not go on . Is there a reset button?
Posted on Feb 09, 2010
SOURCE: Kenmore Model 116 upright beltless vacuum, agitator will not turn
I had the same issue. The holder for the micro switch is very weak and will open up and allow the switch to come loose, and in my case the was not enough slack in the wire. I unplugged the unit, pressed the pedal and laid it down. Open up the bagger door and remove the bag and filter. Remove 4 screws in the bagger compartment, remove 2 screws by InteliClean indicator lights, remove 4 screws on the outside close to the light. You will be removing the blue upper case. Remove the upper case and look on the right where the lower agitator section pivots. There you will see a micro switch. I ended up lifting and tilting the lower pivot section to the side, repositioning the switch in the holder, and then wedging a full glue stick (not melting but wedging) between the white plastic housing and the switch holder. This added the strength needed to the switch housing to hold it in place. Put it all back together, install the filter and bag. This fixed mine. Good Luck.
Posted on Feb 27, 2010
VacuumRepair
  • 438 Answers
SOURCE: Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Posted on Mar 21, 2010
My Henry has stopped working, how much will a new motor cost?
Could be a switch or thermal fuse? Take to a Henry stockist.
Feb 06, 2016 | Numatic Henry Bagged Canister Vacuum
No power, electrical wirring is intact from power plug to switch to pcb
normally with a henry the cable breaks from where it joins the hoover just take apart from hoover end cut about a foot of cable off and then rewire
Feb 09, 2014 | Henry Numatic "" Canister Vacuum
I have taken henrys lid off to look at the motor now he has stopped working
It's possible when you took the lid off one of the wires has come off a switch or the field. It could also mean the motor has gone. Recommend you get it checked out.
Dec 10, 2012 | Numatic Henry Bagged Canister Vacuum
Henry hoover
Hi it can be the connector at the end of the Henry cable inside the cable rewind unit happened to us!
Nov 14, 2012 | Numatic Henry Bagged Canister Vacuum
Hi, My Henry hoover has stopped working about 10
Check the motor brushes as well as the on/off switch.
Sep 20, 2017 | Hoover Vacuums
My hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
Oct 30, 2009 | Numatic HHR-200 Henry Hound Bagged...
Henry's switch has come out.I found the red switch and 2 bent bits of metal. How do they fit together to make him work again?
Rather than coming out, it sounds more like the switch has come apart. It also sounds like you haven't got all the bits. Even if you'd got everything, and knew how to assemble it, there's a good chance it will come apart again anyway. The only safe thing to do is get a complete new switch.
I value your feedback, so please remember to rate this response. Good luck!
Jul 30, 2009 | Numatic Henry Bagged Canister Vacuum
Stopped working
Hi!  Sorry you've had to wait so long for a reply, but I've only just stumbled upon your problem.  You probably don't need help any longer, but here goes anyway! You will not find a fuse, because there isn't one.  If your Henry just stopped, without making any strange noises or smells, it's very unlikely that you have a motor problem.  Quite often the wires can become broken inside the electric cable - with no visible external damage - especially where it enters the plug and can be subject to both bending and pulling stresses.  If the machine came to me for attention, that's where I'd look first.  Check the wires for electrical continuity. If you still need help, and this solution doesn't work, please write again and I'll suggest some less likely things to look for. Good luck!
Jan 25, 2009 | Numatic Henry Bagged Canister Vacuum
Henry Numatic "" Canister Vacuum Logo
147 people viewed this question
Top Henry Vacuums Experts
Gerry Harvey
Gerry Harvey
Chris Nomland
Chris Nomland
Are you a Henry Vacuum Expert? Answer questions, earn points and help others
