Question about Sanyo DP32746 32 in. LCD Television
Will not turn on?
The Tv will simply not turn on...dead as a doornail....any suggestions...is there a reset switch on the TV anywhere?
  • 51 Answers
You problem is in the power supply. I am an authorized tech for Sanyo, and in the Chattanooga TN area. Contact Sanyo at 1-800-877-5036. At the prompt hit the 0 key, and then ask for customer service. They will be more then happy to assist.
Posted on Aug 06, 2008
How do I reset the volume on my tv?
your controlles on the tv set itself goes faulty simply spray some switch cleaner in buttons should sort you out
Sep 15, 2014 | Toshiba 40RV525U 40 in. LCD TV
I turned tv off with then surge protector strip now i get no power to tv no red light no turn on...just dead as a doornail
That is known to sometimes happen...and if it is any consideration it is known to happen accross the board, not just with Scott LCT37SHA :-)
Try a different outlet for a starter, then consdier using this:
http://www.coppelltvrepair.com/p/785/scott-lct37sha-power-supply-board-repair-serivce-for-totally-dead-not-powering-on-or-shutting-down-tv
Nov 17, 2012 | Scott LCT37SHA TV
Power off and not coming back. Changed power connection, checked switch, no power light. Where do I get a power supply for the tv and what does it cost. For initial cost of $900.00 I expected the tv to...
keep it unplugged for about 30 minutes to reset the tv. then try again. also you may have simply blown a fuse inside the tv. open up the back panel right where the plug connect there will be a fuse. if its blown just replace it. if its not blown and the 30 minutes dont work. its not worth finding a power supply (i looked and cannot find one anywhere) and if you do i have seen power supplies for other tvs upwards of a couple hundred you can easily buy a 37 in 1080p tv know for around 350
Mar 16, 2011 | Protron PLTV3250 32 in. LCD Television
1 year old unit simply won't power on, even after connecting to the computer via usb for 8+ hours. Dead as a doornail.
Have you tried the vehicle power cable? That should charge it better and if it does not work then you should contact Garmin or your local dealer.
Cheers
Jul 12, 2010 | Garmin nuvi 765T GPS Receiver
The tv isnt turning on at all what is the problem
Targa 32" LCT TV, No picture/ sound only can hear clicking sound from Kisan KP-301R Power supply board. Have checked output voltages and they are a little out i.e. 16v instead of 17.5v and 10.5v instead of 12v.
Has SAMWHA capacitors but cannot see any bulging or leakage anywhere like other users have suffered so dont know if changing all the caps will solve the issue.
Before it finally went dead LCD TV would switch itself off after some time and just a few days before it dies it started the clicking sound but would then start up okay.
Jun 18, 2010 | Sylvania LC225SSX LCD TV
Dead, no power
It sounds like ze power supply blew when it was being turned off. This seems to be typical of plasmas. Bad power supplys wont let the tv come on and will result in no lights coming on. Since there R no lights coming on, I would suspect the power supply first, followed by the power control board,. and circuit board. It may cost anywhere from $250 to $500 to fix.
May 14, 2009 | NEC PXT-42SX1B 42 in. Plasma TV
A reset switch?
Wait until the power comes back on? Plug the TV back in? The obvious solutions are usually the best.
Sep 02, 2008 | RCA L26WD26D 26 in. LCD TV
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
TV just died...
Hi there!
The fuse may have blown. If so and you know how to check for a faulty fuse inside a TV, it may be worth a shot. Please unplug before opening and replace fuse with same value. If it blows again, you have to have it seen to by a repair technician. Good Luck, Regards, JUS004
Mar 24, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Plasma TV
This usually means that the TV was last shutoff by using the sleep timer. When that happens it usually needs to be turned on and off 2 or 3 times, or try using the main power button on the tv or simply unplugging it. A full reset probably wouldn't hurt either.
Jan 21, 2008 | Televison & Video
Sanyo DP32746 32 in. LCD Television Logo
140 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
