Question about Panasonic PT-52LCX65 44" HDTV
Panasonic pt52lcx65 problem are two blue dot
There are two blue dots on the screen one at upper center, and the other upper left. what's the problem, what part do i need, and the part number if you can
    Genius:
  • 1,689 Answers
Flavrlen, looks like a part of your TV needs re-attaching or replacement, depending on where the blue spot is there is a greater possibility that the EEPROM (IC) has been dettached, you may get this repaired or better off, replaced with a 128K, its just 8 bucks so no problem on that part. getting it in is the tricky part that will require professional physical repair.
if you want to you may contact panasonic to doublecheck,
here's a price list of the parts of your TV.
http://www.pasc.panasonic.com/Epartr/PartsList.asp
Posted on Jul 09, 2008
    Genius:
  • 1,847 Answers
It seem like dead pixel, how big are the dots?
  • Legin Varghese
    Legin Varghese Jul 09, 2008
    get your lenses cleaned also and also check for purity from each gun/red/green/blue.
    if the unit is in warrenty contact Panasonic service center.
    Master:
  • 848 Answers
The degaussing circuitry is terminating suddenly instead of gradually as it should. The most likely cause is a bad solder connection to the degauss thermistor or posistor or something feeding it.
  • gopinath pasupathy Jul 09, 2008
    To solve this problem you need to upgrade eprom........You can do this by contacting panasonic service center
AFTER REPLACING THE LAMP, I HAD TO PUT THE COVER ON AND NOW THE SCREEN HAS TINY BLUE DOTS AND THE POWER LIGHT STAYS GREEN. THE LAMP LIGH IS NOW ON AND RED
The blue dots are due to a failing optic block. The lamp is only making them show up more obviously. The TV is probably failing as the blue dots will get larger and eventually take over the screen.
Sep 12, 2015 | Panasonic PT-61LCX65 61" Rear Projection...
Blue dots on screen. Blue band on on/off side of screen.
blue dots on screen,bright blue haze right corner to north westpast center of screen.
May 24, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Little blue dots on screen and large blue haze in upper left corn
Sounds like the light engine is going bad...that's why they stopped making these rear projection sets using LCD's. Costs almost as much as a new set! But get a second opinion before trashing it.
Apr 15, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Blue dots center and yellow stain right hand corner on 60'' sonytv
Yes, I do. It needs a new light engine. Very costly repair. However, Sony has extended the warranty on many of these LED projector sets. You need to call a local Sony authorized service center and see if your model is covered. Otherwise this repair could run over a thousand bucks.
Jun 14, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony grand wega kdf 50we655 blue dots everywhere
thats a common symptom for that model which is usually related to the optical block. Very exspensive repair. Check with a sony authorized repair center as Sony has recognized the problem and offer assistance with certain models yours may be one of the ones affected.
May 23, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue section (corner) and blue dots
This set has no internal manual adjustments for color. The Tracking or B&W balance is accessed via the service menu. I don't suggest you attempt to adjust without instrumentation. the trouble with your set is not an adjustment. Most likely the Optics are at fault. This model has had issues with filters in the optics being destroyed over time by the lamp. The blue haze will get worse and continue to grow over the whole picture. The only option is to remove the Optics (light engine) and sent it out to be rebuilt.
Apr 14, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blue dots and blue color
my sony is 4yrs also it has blue dots on the left side from top to bottom and a blue blob on rt. bottom corner no longer under warr. please send repair solution.
Jan 12, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Kf-42610 blue hue and blue dots on screen
Hi Guys
The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
Sorry to have been the bearer of bad news. Good luck : )
Aug 29, 2007 | Sony XL-2100U Projector Lamp for...
Panasonic PT-52LCX65 44" HDTV Logo
127 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
