Question about Car Audio & Video
1-sel shows up on my 97 jeep grand cherokee limited stereo when i turn key on and i have no sound. is this a fault code or error code ?
SOURCE: 97 Jeep Grand Cherokee Limited Stereo problem
If you still have audio but unable to turn the volume, there are 02 possible problem:
- the volume control is defected will not respond ( electronic volume control; need logic low/high to activate the audio )
- the front control PCB is broken ( can be fixed if there is a small cracked )
If no audio at all then most likely audio output IC defected
Posted on Feb 25, 2008
  • 55 Answers
SOURCE: fault code P0720
code po720 is the output speed sensor malfunction
Posted on Jan 29, 2009
  • 323 Answers
SOURCE: Jeep Grand Cherokee Limited P0700 diagnostic problem
P0700 means there is a transmission fault code in the transmission controller. Since the transmission controller doesn't have a light attached, it tells the engine controller to turn the light on using this code. You'll have to access the transmission controller to further diagnose the problem.
Posted on Jun 14, 2009
  • 56 Answers
SOURCE: need wiring diagram for a 95 Jeep Grand Cherokee
http://www.modifiedlife.com/car-stereo-radio-wiring-diagram-1995-jeep-grand-cherokee/
Posted on Feb 20, 2010
  • 264 Answers
SOURCE: I need a copy of the fuse box underneath the
Here You are...
Grand Cherokee fuses
1999-2004
Junction Block
Cavity Fuse Color Description
F1 -- -- Spare
F2 -- -- Spare
F3 10 Amp Red Headlight high beam left
F4 15 Amp Lt. Blue Flasher, hazard switch (see Junction Block diagram above for location of turn signal Flasher relay - Mopar p/n 4686094)
(Repair tip: WJ flasher repair)
F5 25 Amp Natural Radio amplifier
F6 15 Amp Lt. Blue Park lamps
F7 10 Amp Red Interior lights
F8 15 Amp Lt. Blue Overhead console, rear wiper, IP lights, rear flipper glass solenoid, power locks
F9 20 Amp Yellow Power outlets
F10 20 Amp Yellow Adjustable pedals (2002-2004 only)
F11 10 Amp Red Rear window defrost indicator
F12 10 Amp Red Auto shutdown relay / "Fuel"
F13 -- -- Spare
F14 10 Amp Red Headlight low, left
F15 10 Amp Red Headlight low, right
F16 10 Amp Red Headlight high, right
F17 10 Amp Red Instrument cluster, diagnostic connector
F18 30 Amp ? Trailer tow
F19 10 Amp Red Anti-lock brakes
F20 10 Amp Red Ignition Run / Heated seats / A/C Heater control / Flasher - Left and Right turn signal switch sense
F21 10 Amp Red Ignition Run / Start - PDC (Power Distribution Center)
F22 10 Amp Red Ignition Run / Start
F23 15 Amp Lt. Blue Brake switch
F24 15 Amp Lt. Blue Foglamps
F25 20 Amp Yellow Accessory delay relay (sunroof)
F26 15 Amp Lt. Blue Cigar
F27 15 Amp Lt. Blue Rear fog (export)
F28 10 Amp Red Body Control Module, Acc/Run
F29 10 Amp Red Rear wiper switch. Washer motors
F30 15 Amp Lt. Blue Radio
F31 10 Amp Red Ignition Start
F32 10 Amp Red Ignition Run / Start - Airbag
F33 10 Amp Red Ignition Run / Only - Airbag
C1 20 Amp Yellow Wiper (Circuit Breaker)
C2 20 Amp Yellow Seats (Circuit Breaker)
C3 -- -- Spare
Posted on Mar 07, 2010
Where are the fuse location cluster in a 97 jeep grand cherokee loredo
See this... http://www.jeepforum.com/forum/f13/wheres-interior-fuse-box-97-grand-cherokee-704339/
Jun 28, 2014 | 1997 Jeep Grand Cherokee
Evap leak test
No fault code set? Try the key dance: ignition switch off/run three times and leave in run at third time. Odometer shows Done when no faults, or a fault code(s).
The evap test runs automatically and checks for leaks in the evaporative control system.
Nov 19, 2013 | 2003 Jeep Grand Cherokee Limited
I have a 95' Jeep Grand Cherokee Limited with a
Are you check your previoud questions: check_engine_error
Keep us updated.
Jun 07, 2011 | 1995 Jeep Grand Cherokee
Trouble code po351 engine stalls, tach also goes
http://forums.cnet.com/7723-7811_102-270706/97-jeep-grand-cherokee-stalling-not-fixed-yet/
Feb 09, 2010 | 1998 Jeep Grand Cherokee
Jun 14, 2009 | 1998 Jeep Cherokee
1997 Jeep Grand Cherokee Limited
If that many things went out at the same time its most likely a fuse issue. There are usually 2 fuse panels in the Jeep - one under the hood and one by the steering column. Check the proper fuses to see if they blew out and replace if needed.
Aug 04, 2008 | 1997 Jeep Grand Cherokee
Dec 19, 2007 | Cherokee (REF) AM/FM Stereo with CD Player...
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
