Question about Savin Office Equipment & Supplies
Any idea how to replace the fusing oil in a Savin c3224 copy machine
Streaks in sheet copy
Posted on Jul 13, 2008
How do i reset a fusing unit counter on a CLP22
Hi. First of all did you have a code to tell you to replace the unit? I would like you to put the old unit back in and see if it lets you restart your printer. If it comes back up you have a problem with the new fuser you received. Take a few seconds to compare the unit and make sure all looks the same. If it's a remanufactured some times little things like tabs and the such get bent or broken. It should reset the counter when you set the new one was replaced. Hope this helped. I do get a little wordy at times
Feb 04, 2015 | Savin GENUINE RICOH FUSER UNIT (402451)...
Savin c3224
This typically happens when trying to copy currency & certain other sensitive docs on all color Ricoh devices. This includes Savin, Lanier & Gestetner. It may work if you reduce the image enough.
Feb 20, 2014 | Ricoh Office Equipment & Supplies
We have a Savin 2545 copier. We received an error message SC 726. Can you give me some idea what we need to check?
That error is for the shift tray motor in your finisher where the copies come out. The tray should move from side to side when you switch the machine off and on. It sounds as if it is binding for some reason.
Mar 14, 2011 | Savin 2545DP Black and White Copier
What does functional problem SC541-00 on a Savin copier 2035DPE
SC541 is a defective thermistor, clean or replace the two thermistors (Edge and Center) on your fusing unit. after replacing or cleaning reset the SP Code 1. On the operation panel, press Clear Mode ". 2. Use the number keys to enter 107. 3. Press and hold Clear/Stop # for three seconds. 4. On the touch-panel, press Copy SP. then turn off and on the machine
May 18, 2010 | Office Equipment & Supplies
Savin 9940DP ''Set Key Counter''
Key counters are used when a copy machine is set up for public use where copies are charged on a per copy basis. Key counters look like small boxes that plug into the side of the machine and they have a counter on them that looks like a cars odometer. A user plugs in the key counter, makes copies and then takes the counter to a register to pay for the copies they made. Sounds like that is what you have going on.
Nov 02, 2009 | Savin Office Equipment & Supplies
PRINTED PAGES ARE BLANK AFTER REPLACING PHOTOCONDUCTOR
The machine should automatically recognize the new PCU. Blank copies would lead me to think you have further problems, charge corona? transfer issues? If you try to make a copy and open the front door real fast when the paper should be at the transfer unit, is there an toner image showing on the drum? If yes, then you have charge but not getting transfer. This is a hard problem to troubleshoot without seeing machine. Anyway good luck, please rate this. Thanks ..... Wait... just had a thought. On the shaft, on the inside of the rear frame, that drives the drum there is a coupling that is spring loaded. Sometimes the shaft gets gunked up and coupling does not pop out not connecting to the PCU, which could cause blank copies and will still say replace pcu. You could add a couple of drops of oil to that shaft to loosen it up if that's the case.
Jun 30, 2009 | Savin Office Equipment & Supplies
Savin 4035Esp - Functional Problem Message with Code SC863
Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
May 15, 2009 | Ricoh Office Equipment & Supplies
126 people viewed this question
Top Savin Office Equipment & Supplies Experts
Adorjani Laszlo
George Mclaughlin
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
