Question about Traeger Industries BBQ100 All-in-One Grill / Smoker
My auger does not work. the hot rod funtions but the auger does not work
  • 8,220 Answers
Maybe it needs to be repositioned. Some of them have a switch that defeats it unless it is in the correct position
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 03, 2011
Why does Snow not throw? The auger does not turn.
The handle that makes the auger turn has a nut on it. Tighten that nut all the way up the rod.
Mar 07, 2015 | Garden
Tip
What to do if your ice maker stops working
Many refrigerators now come with built-in ice makers. Ice makers are very convenient, but occasionally they'll develop problems. Why pay a repairman to come out if the fix is easy and you can do it yourself?
Here are some tips for fixing an ice maker that stopped working.
- Check the on/off switch
Freezers with automatic ice makers have a switch that is used to turn the ice-making feature on or off. This switch is typically a rod above the ice box; when it's lowered, the ice maker is on, and when it's raised the ice maker is off. If the ice box fills up with ice, the ice can force the rod up, turning off the ice maker. Check this bar to be sure it is in the lowered position.
- Check if the auger or chute is clogged
Your ice maker has a chute where the ice falls from the freezer into the external tray (where a glass is placed). There is also an auger inside the freezer that rotates to drive the ice forward from the ice box into the chute. Check the chute for large chunks of ice that may be clogging it up, and check the auger for ice cubes or chunks that might have gotten wedged between the auger and the freezer, causing the auger to be unable to rotate.
- Check the water line
If you still haven't found the problem, check the water line leading into the freezer. This water line has its own valve. Make sure the valve is open, allowing water into the freezer to create the ice.
on Jan 23, 2011 | Refrigerators
Treager smoke auger won't turn
If the auger won't turn because it's jammed, here's details direct from Treager
Elswise, I would check your electrical on the back of your control panel. There should be three sets of two-wire leads: (1) Purple/White=Hot Rod; (2) Orange/White=Induction Fan; and (3) Red/White=Auger. Obviously, check the Red/White leads for voltage and continuity.
Dec 10, 2013 | Traeger Industries Grilling
Honda hs55 when handle depressed blower fan moves at fast speedauger turns very slow.if auger makes contact with snow auger and blower fan stopsnew belt was installed no slippage of belt present
I suspect that all is needed is a little adjustment of the rod attached to the handle, which hooks on a lever at the bottom of the snow blower drive axle case. Try adjusting the nut two turns, that will pull the rod a little bit more and engage the rubber faced drive wheel, giving it a snugger connection. If this has been checked or still does not help, then I would check inside the case where the drive axle is located. There is a rubber faced drive wheel (as noted above), that runs against a smooth flat metal pulley. The rubber on the drive wheel could be worn out and not engaging properly. I would also check on the front of the case where you installed new belts to make sure that the brake shoe puck that connects to the auger pulley is not binding or perhaps has flipped out of its normal location.
Dec 05, 2013 | Honda Piston Rings Snow Blower Lawn Mower...
Icemaker is making ice but the ice dispenser is not working
Check the ice storage container. The ice dispenser will not dispense ice until the first supply ice has dropped into the ice storage container.Remove excess ice from the back of the ice container. Make sure ice cubes are not jammed between the ice maker and the back of the ice container.
The auger won't engage or turn to dispense ice.Remove the ice bucket and with a hair dryer warm up the inside where the fork is that turns the auger in the bucket and try it and if this does not help then you will have to replace the auger motor ,, chances are the motor is just froze up .--------
If there is nothing jammed then try this./Remove the ice bin out.And then clean the ice bin.
Rotate the auger with your hand.If its hard then there is problem with auger motor.If the auger is not rotating fine then its faulty auger motor or the auger motor is frozen,if you notice ice getting collected there.
Take a hair dryer and blow hot air on the auger motor for few minutes.Take care you dont blow hot air continuously.
But if that is not helping then disconnect auger motor connecting wire wait for 2 minutes clean the connector and reconnect the connector back and see.If that is not helping at all.Then,replace the auger motor.
To see how auger motor looks.Please click the link below:---
http://www.appliancepartspros.com/part_details_lgimg.aspx?part_id=3965455&image=0
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 21, 2011 | Frigidaire FRS26H5AS Side by Side...
How to adjust a 9460897 mtd snow blower auger clutch cable.
On the handle end (usually) of the cable is a curved metal connector. Attached to the connector is a threaded rod with a nut. Attach a pair of pliers to the threaded cylinder that the threaded rod goes into. Loosen the nut. Turn the threaded cylinder into the threaded rod to tighten or out to loosen. When you have the correct adjustment, tighten the nut back down onto the cylinder. To be correctly adjusted, pull the cover off the auger belt and push down on the handle. The spring attached to the cable at the pulley end should stretch out when the handle is fully depressed. Spring tension keeps the belt tight. iaff801.jpg
Feb 15, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
Snowblower doesn't throw the snow very far, and every time I stop it, it takes a while for the auger to start turning fast enough to blow the snow. Feels like the torque isn't there. This is a Husqvarna...
The most common cause of this is the drive belt is worn.
If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission.
With the engine not running, have someone depress the drive lever and check the blower belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
You can get parts for you Craftsman and most Husqvarana, MTD made models through searspartsdirect.com. You can also get parts through jackssmallengines.com or your local dealer.
If you are unfamiliar with repairing machines take it to your local dealer. They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions to troubleshoot this problem farther. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Garden
How to charge an auger on traeger grill
Turn the control on high and wait about three minutes. Shut contol off and restart in about 1 minute, This should have enough pellets in the auger to start before the hot rod shuts off. You can also put a hand full of pellets in the burn pot and usually bu the time these pellets are burned out the others are there. A couple of cycles usually will start them.
Apr 16, 2010 | Traeger Industries BBQ100 All-in-One Grill...
Matag fridge msd2351hew icemaker ice and water work and cubes come of crushed ice dispencer. There is a capacitor connected to auger motor.Is this the problem? There are no other electrical parts.
If you remove the bin and look on the bottom of it you will see a rod running from front to back,this opens and closes the crusher see if it moves freely, if not dump the ice and rinse the bin out with hot water till it moves freely,if so,with the door open set the dispenser to cubes leave the bin out push the light switch in and hit the  dispenser button you should hear a loud pop and see the actuator by the auger motor move up,and drop down when you release it.
Aug 22, 2009 | Maytag Refrigerators
Traeger Industries BBQ100 All-in-One Grill / Smoker Logo
395 people viewed this question
Top Traeger Industries Grilling Experts
Gary Kenady
Gary Kenady
Craig Butler
Craig Butler
Paul Carew
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
