Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
I have an Amana LW9203W Washing Machine that is leaking oil into the tub during my wash cycle??? what is the problem...I have polka dotted grease stain on my laundry.
  • 472 Answers
Sounds like you have a bad transmission seal and your going to need to replace... there is a seal in the tub between the transmission that could also have failed but the transmission should not be leaking oil regardless on the floor or in the tub so sounds like you are going to need a new transmission and tub seals.... good luck
Posted on Jan 03, 2011
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Amana washer tub rotates counterclockwise during wash cycle.
The washer has a transmission.why are you openning the top it's a safety.the transmission may need to be replaced,You may be better off getting a new or new used washer,the transmissin is very expensive
Jul 29, 2010 | Amana Washing Machines
Oil is spewing into the wash tub during the spin
This may be a busted tub seal, but is usually caused by the outer plastic tub retaining grease and debris from previous loads. I would try running a hot water only wash cycle at full water capacity and adding a strong degreaser. This should emulsify any left over grease while also washing out the outer tub. If the problem persists, you may need to repeat the procedure. Remember that your washing machine transmission is located below the drum and tub assembly and is full of oil, but that oil simply cannot travel uphill.
Mar 13, 2010 | KitchenAid Superba Architect KSCS25INSS...
Noisey spin
The noise is from the transmission and is usually pretty expensive. You really are better off getting a new washing machine.
Feb 24, 2010 | Amana DLW330RA Top Load Washer
Water is leaking out of washer; think it is during the water draining cycle
The AMANA washer has an outer tub and a water pump. Please check these to make sure you can see where the leak is coming from and replace. Also, if your machine has a dispensing system, check all hoses for THAT system. If upon fill up the out tyub HOLDS WATER and DOES NOT Leak, then the outer tub is okay. Carefullky look at the water pump on drain.
Nov 16, 2009 | Amana ALW780QA
My washing machine makes machine gun sound and doesn't wring out clothing properly...noise is only on wringing out cycle
Interesting... I don't have a solution, just a related problem. Belt broke and after repair, I observed that water is leaking from the bottom of the tub during wash cycle. I guess it could be a cracked tub (not too likely) or a gasket around the agitator bearing. I'd like some advice on this as well.... and how to get to it. The drive belt was a pain....
Sep 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Water leak
POSSIBLE LEAKING PUMP OR TUB SEAL
Apr 16, 2009 | Washing Machines
Amana top load washing machine will not stop cycling through or shut of. Just keeps going through all the cycles.
Try this for you timer.
That is if you are handy and can open the washer to work on it.
UNPLUG FIRST!
Just carefully clean all the contacts and put contact grease on them.
Feb 16, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
90 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
