Removal of shipping screws on new Bosch washing machine
I just bought a Bosch washer and when you turn it on it vibrates all over the place. My husband has taken great care to make sure it is on a level floor, but it still vibrates. My friend just mentioned that there is something called shipping screws attached to the back of the machine that, unless they are removed, will cause the machine to jump and vibrate. How do we get rid of the screws?
Thanks very much.
  • 770 Answers
There are 3 or 4 depending on the model 3/8" bolts they need to be unscrewed completely and removed for the machine to operate properly the how to in in the use and care guide with the install instructions sheet
Posted on Jul 09, 2008
What is causing the tub of my top load washer to bang against the back side of the washer while it is in the spin cycle? The washer also vibrates violently.
sounds like the damping system is the problem. The drum may have moved out of place or the damper(s) have become faulty in some manner. I used to have a hotpoint washer that tried to destroy the room it was in by travelling around it after the drum had fallen off its mounts. I bought a new machine, my thinking being that there is no point in taking a risk of having a real disaster if I set it to wash and then go out.
Bosch / zannusi / siemens make good machines
Dec 18, 2015 | Washing Machines
The washer vibrates in the wash and spin cycle .
Try checking for the shipping screws, did you remove them? They are there to prevent the drum moving during transport but if left in the whole machine will try to jump about.
Jun 10, 2011 | Amana NAV5800AW Top Load Washer
I just bought the affinity front load washer and did my first load of laundry. During the cycle, it vibrated so hard and literately moved one foot from the original location. What is causing the washer to...
Sounds like the shipping bolts are still in place. There are four bolts on the rear of the unit. Remove them and it will fix the issue.
Apr 22, 2011 | Washing Machines
It walks all over, does not matter the size of load.
Make sure that you properly removed all of the shipping bolts and packing material when you installed the washer. This could cause the machine to vibrate. I provided an image below regarding the removal of the transport bolts and packing of the washer. I also provided a link below for the entire installation manual for your washer. Carefully review this entire manual to make sure that the washer is properly installed.
If the washer is on unstable flooring, it will vibrate and walk. This type of washer works best when it is on a concrete slab. If it is on a wood floor, you may need to reinforce the foundation to eliminate vibration.
Mar 20, 2011 | Frigidaire Affinity ATF7000E Front Load...
Washing machine vibrates and starts to wobble excessivly had a repair man look at the machine he said he could not find anything wrong all the shocks and stabilisers were ok.just had a new kitchen...
get another man out,,,,,your washer has a fault with its stabilisers,,,it may need to be reset to your floor is it wobbles its that or your putting the wash load is lumpy,,,
Nov 28, 2010 | Bosch Washing Machines
Washing machine has a seizure during the spin cycle.
Try leveling the washer so that it is about half a bubble biased towards the rear. This usually helps front loading washers balance properly even if the installation instructions say that it should be perfectly level. This can also aid draining problems.
Also, some newer front loading washing machines are simply prone to dramatic vibration even when they is "anti-vibration" or "vibration reduction" systems. You can never go wrong installing an anti-vibration pad under the washer. Good Vibrations Inc, Kellett Enterprises and The Vibration Solution all have good products. The Vibration Solution seems to have figured out the best solution and offers excellent support and return policies.
Washer anti-vibration pads
If all else fails call the retailer and ask for an exchange.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Brand new washing machine wandering on spin cycle
It sounds like the transit bolts or some of the packing is still in place. Running the machine with these in place can do serious damage.
Thankyou for using Fixya.
Feb 14, 2009 | Washing Machines
Movement when spinning
Yes. Did you buy this new or used. ????? Please le me know. I have seen the gromot on these wear out quickly. You need to get it repai if under warrenty .
Feb 10, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
LG Intello Washer DD 7Kg. WD-1460FHD
did you remove the shipping bolts before you starting using it consult your owners manual under installation for location and removal procedures all washers have them to stabilize them during shipping
Jan 02, 2008 | Washing Machines
Bosch model 3301
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. The exit hose should be at about 3 feet from ground level; pump pumps out over this height.
Rate me pl.....if helped.
Dec 03, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
359 people viewed this question
Top Washing Machines Experts
