Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
The control panel on the door does not seem to work properly. When Cube is chosen, no cubes are released. Same situation for crushed ice. Also, water does not come out of the dispenser. The rest of the refrigerator seems to work normally. The ice maker seems to work normally. I have checked the water source going into the refrigerator and the water is provided into the unit. When I activate the dispenser, there is no response. With the dispenser activated, every 5 or so seconds, the freezer and refrigerator temperature flashes, then the display goes dark until the next 5 seconds passes. Any thoughts or suggestions would be appreciated. Thanks
  • 472 Answers
YEAH YOU HAVE ABAD DISPENSER CONTROL BOARD AND OR SOLENOID IS SHORTED IN THE DISPENSER... not to bad to change remove the outer cover and you should be able to see up there and how it operates... there is a control which you already know the display that feed power and also a actuator that controls the door flap. it is going to be one on the two...
good luck and repost if you have anymore questions ... please vote...
Posted on Jan 03, 2011
Why does my cube ice does not dispense ice?
Check to see if the actuator is lifting up. sometimes these freeze and won't lift the arm that releases that grinding blades. It is in the back panel behind the ice bucket. Remove the bucket and hit the light switch. Then hit the ice actuator flap on the door and see if the little "stirrup" looking thing jumps up. There is usually a clicking sound when it lifts. it could be frozen or just bad.
Jul 23, 2014 | Frigidaire Refrigerators
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
I have model# FRS26R4AW5. The ice dispenser wil
I have a few ideas for things to try. On the bottom of the ice cube holder I believe there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. Make sure this metal rod is free to rotate. Sometimes it gets stuck in one position. The position of the plastic piece inside the indent in the rear of the freezer is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced. I hope this helps you out.
Jan 09, 2010 | Electrolux Refrigerators
Crushed ice option don't work properly . samsung RS2530B
if it new call sears for service...with crushed ice the augar moter turn the other direction... it must not be turn the other way could be a switch in the control...
let me know for it help if NOT please let me know and I will be glad to do more in depth.
Sep 26, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
MAYTAG Ice control doesn't change from Cubed to Crush
If you prefer ONLY cubes , remove the ice bin and 1 or 2 screws hold the long rod attached to the bin . Without this rod , you'll only get cubes . With the bin removed , the square hole where the rod inserts in the rear freezer wall , you'll see a square , white , plastic "gate" . Asolenoid with a plunger , raises this gate for cubed ice and keeps it lowerer for crushed ice . Usually this "gate" plunger , rusts , thereby replaceing the solenoid and plunger would have to be done . Without the rod on the bin , the inner flap would open automatically , dispensing cubed ice .
Aug 16, 2009 | Refrigerators
Only get crushed ice, even when Cube is selected
Hi
1 thing to try first is pull ice bucket out and make sure the bar at back goes through the vavle in rear panel. cause if it isnt then when you select cude the vavle isit lift up.
regards
Mar 22, 2009 | Electrolux Refrigerators
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
132 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
