Question about Brother HL 1440 Laser Printer
I guess I need to clean the printer it has two faded lines on the paper and of course what I need to read is in those lines....
Why do I have white / faded print when printing black? It also has problems printing straight lines - sometimes jagged sometimes just faded.
I do not know for sure but it sounds like the paper is not griped properly, this would cause the jagged lines. I would try another ink cart when the loose paper problem is resolved. I hope this helps.
Jul 23, 2014 | United Stationers HP Officejet Pro 8600dn...
Anything I print looks really faded.
Did you clean the print heads and/or re-calibrate the printer after installling the new ink. It is possible, however, to have gotten a faulty cartridge.
Hope this helps
Randy
Aug 31, 2012 | Canon PIXMA MP160 All-In-One InkJet...
Canon Printer - Pixma 5000 Trying to print out pages of text. The text is coming out with a line printing normally - then a block of text / lines missing completely - then tops of line or bottom of line...
pull out the black cartridge then get a tissue paper try pressing the nozzle again the tissue paper but not so hard then release look for the straight line that appear on the tissue paper if it is not change it
Aug 07, 2011 | Canon Office Equipment & Supplies
My samsung clx 3160fn prints with a faded streak in the center of the paper
There is some-thing that is dirty that is making contact with the paper.
My guess is a roller or a little metal guide wheel or the like.
Clean it with tissue paper.
Use the already printed page to line up to see where about the source of the line is comming from.
Till next time!
damnor01
Apr 14, 2011 | Samsung CLX 3160fn All-In-One Printer
I have a HP 7590 printer and it sometimes skips line or some of the lines are faded when printing black .
Perform the following steps to reduce or eliminate faded or grainy lines:
  1. Print at a higher quality setting.
  2. Verify that the paper you are printing on will lay flat. Paper that is not laying flat can cause banding when the paper transitions over the rollers or cause the print cartridges to scrape across the surface of the page. Check the top sheet of paper by removing it from the all-in-one and placing it on a flat surface. If the paper does not lie flat, bend it in the opposite direction to straighten it. Figure 3: Faded or grainy bands in print caused by paper that is not flatc00178858.gif 1 - Faded or grainy bands due to roller transition with paper that is not flat. 2 - Faded or grainy bands due to print cartridge scrape on paper that is not flat
Jan 06, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
PRINTING ON PAGE IS VERY FADED AND SOME PARTS NOT PRINTING AT ALL
First, checkthat the USB cable is secure in both the printer and the computer and that theprinter is sitting on a flat surface. The printer may not work if it is tilted.
Next, run a printer check to make sure the printer is operational. To run aprinter check, turn off the printer and the computer and unplug the USB cable.Turn on the printer and press the Maintenance button. Use the down arrow buttonon the printer to highlight More Options on the display screen and press OK.Highlight Nozzle Check and press OK twice. If a page prints out, reinstall theR300 software on your computer.
Lines inPrintout
R300 mayproduce printouts with light horizontal lines that are not a part of theprintout. This is called banding and can have several causes. First, trycleaning the printer head to clear any clogged nozzles. To clean the printerhead on the R300, press the down arrow button to highlight More Options andpress OK. Use the arrow buttons to highlight Head Cleaning and press OK twice.The printer will take about 30 seconds to clean the print head, after which youshould run a printer check as described above. If the printout has gaps, pressthe STOP button to run the print head cleaning feature again. Once there are nogaps in the printout, press OK.
If the printout still has banding, open the Print window on your computer andclick on Properties. In the Properties window you can choose the print quality,speed and printer type. Select a higher print quality and a lower speed andmake sure the paper type matches the type you are using for the printout.
Finally, check that the ink cartridges are not empty or close to empty andreplace them as needed.
Faint Printout
If your printout looksfaint or faded when using the R300, try cleaning the print head. Next, replaceany ink cartridges that are old, low on ink or out of ink. Check that the papersetting on the computer matches the type of paper you are using for theprintout.
Another potential cause of faded printouts is incorrectly loaded paper. Sometypes of paper have a printable side that is whiter or shinier on one sidecompared to the other. The printable side of the paper needs to be loaded intothe printer face up.
Nov 20, 2010 | Epson Stylus Photo R300 InkJet Printer
The printing quality either in bw or color is not good
Very impotant to select type of using paper. Some thick or thin paper need to use special settings in menus of pinters. Please read user manual in chapter "working with paper". Use must use only original Samsung toner cartridges if you dont want to see faded on other side.
Dec 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Printing won't work.
Good day sir/maam, hi, when you test print it usually prints letters and no lines are printed. try first if the printer is setup to economy/draft or pictures, if lines are faded, the ink cartridges maybe dirty. manual cleaning is needed, the ink path starts from the ink cartridge to the cradle or carrier then to paper. so any dried ink that blocks the path can affect the printout. you can use warm water to loosen dried ink. remove the cartridges and cradle from the printer as you clean them.
Oct 27, 2009 | Office Equipment & Supplies
HP 7410
do a self test on the printer and see what that looks like.
Apr 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Faded line going through
Anne, This could be several things-here is a list... 1. transfer roller or belt dirty, especially if inside of printer looks like it needs a cleaning. You could vacuum with toner vacuum or take it in for service. 2. scanner mirrors dirty. would need to be serviced by a technician. 3. scanner toner shield out of position-tech needed. 4. toner cartridge needs to be shaken horizontally-toner could be all on one side of hopper. 5. the fusing section could have work rollers, they sometimes get scored and leave a strange brownish line on the page that sort of fades if you print multiple pages. Again, tech would be needed. Anne, thanks and good luck.. Thanks and good luck...
May 11, 2007 | Dell 3100cn Laser Printer
Brother HL 1440 Laser Printer Logo
29 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
